Air Temp sensor mod, POORMAN STYLE...
So this friend of mine tells me that you can just replace the air temp sensor by the intake with a 4.7K resistor. At first I didn't believe him, but I did a search and it apparently works. The resistor makes the car think that cold air(32F) is coming in. It is also apparently the same thing that they sell on ebay for $20. The resistor itself only costs about 20cents and I want to try it. Has anyone done this and did it actually work for you. There are tons of posts about this but they all bash people for being stupid enough for spending money on that crap. Well it's 15-20 cents, but I don't want to screw something up and pay tons for 15cents of crap that ****ed my car up...
Re: Air Temp sensor mod, POORMAN STYLE...
1) just try the mod at your own risk and if it works, post it.
2) everyone has bashed the idea, you asking again is only going to cause more bashing. So make a decision on your own.
Why not be a pioneer and try it. If your friend is confident enough that it will work tell him to install it. The worst that could happen I would think is that you would have to put the old one back on, and possibly clear some codes.
Good luck.
So what is the advantage of tricking the ecu into "thinking" it's receiving colder air than it really is?
Re: Re: Air Temp sensor mod, POORMAN STYLE...
Heck, maybe I should dig out my FSM and check the explanation. I can be the guinea pig if no one wants to risk it
Re: Re: Re: Air Temp sensor mod, POORMAN STYLE...
Nope. Not unless the car runs unusally lean. Plus leaner mixtures make more power than rich mixtures(within reason).
Originally posted by 95bluse
Car run's a higher ratio fuel mixture, hence producing more power or that's the theory anyway. I've heard of guys doing this for 1/4 mile runs. The downside is your fuel consumption would suck much more than it is now with this cold snap.
Re: Re: Re: Re: Air Temp sensor mod, POORMAN STYLE...
More fuel in the cylinder (rich) would make you run slower, a leaner mixture with more oxygen is ideal for power, that's pretty much what nitrous does, nitrous contains much more oxygen than our atmosphere.
A lot of people think that a little richer mixture will make the car faster in the 1/4. Thats why the Honda guys pay $75 for a gizmo that screws down on top of the stock FPR to increase the fuel pressure.
I guess it makes them feel good. Only way to prove something like that is on a dyno.
If you can replace the temperature sensor with a resistor, then the actul temperature sensing device is a Thermistor, basicly a resistor that changes resistance with the temperature (usually inversely proportional). If you put a set resistance, the vehicle will only run optimally at the corresponding temperature to that resistance. If its too cold, you'll get a lean mixture, and if its too warm, you'll get a rich mixture.
Bottom line, don't defeat this sensor. There's no good reason for it, it will only hurt your performance, or at the very least, fuel economy.
Originally posted by hacim105
If you don't want to get flamed in the future you have 2 choices.
Thanx for the reply *******. You were the only one to be a **** about it. I thank everyone else for thinking about it and discussing it. This exact idea hasn't been discussed much. I found an old post by someone on the 5th gen forum that was exactly the same as mine but he didn't get any replies. My friend already does have it on. He has it on his CAMRY, the thing is I might need a different value resistor. Also with this mod the engine actually lets more gas into the engine to even out the a/f ratio. His gas mileage dropped about 11 gallons a fill-up...
Dave
As someone else posted, replacing a thermistor with a resistor is a big no-no. Replacing a knock sensor with a resistor on the other hand, saves me some bucks
Re: Re: Re: Re: Re: Air Temp sensor mod, POORMAN STYLE...
Re: Re: Re: Re: Re: Re: Air Temp sensor mod, POORMAN STYLE...
Originally posted by Romeo
you put in a resistor instead of your knock sensor? what resistor and what are the effects of it?
Downsides are:
1. I am running the risk of detonation (bad), if I happen to get a bad tank of gas (hasn't happened)
2. I'm not sure if the KS sends a variable resistance during normal driving, there by continuously varying the timing. I haven't noticed any adverse effects really.
Re: Re: Re: Re: Re: Re: Re: Air Temp sensor mod, POORMAN STYLE...
fastcarny
10-06-2015 10:42 AM
sdotcarter
09-02-2015 09:53 PM
