straigh pipes question
Old Jan 22, 2003 | 08:30 PM
Rufus's Avatar
those running straight pipes (no cat) what do you do with the o2 sensor attached to the cat? and the one attached to the precat (y-pipe)??
Old Jan 22, 2003 | 09:42 PM
meccanoble's Avatar
Sports Button FTW
Originally posted by slammed95
The straight pipe should have a o2 sensor bung, and the y-pipe should also have the holes.
i have a straight pipe and it doesnt have any holes for the o2 sensor. The o2 sensor doesnt hook onto the pre cats on the 97+ maxima's, they hook up to the y-pipe, that's why these work great (no triggered ECU's) on 97+ maxima's. if you have a 95-96, then u will have a problem because i think the o2 sensor is plugged on the cat....
Old Jan 22, 2003 | 10:36 PM
Stillnmax's Avatar
cali spec owns you
Old Jan 23, 2003 | 08:09 AM
1MAX2NV's Avatar
Not exactly....97/98/99 fed spec still have an O2 sensor in the bpipe. You could still get the CEL. Yep...1999 cali-spec ownz you when it comes to striaght pipe. Our last O2 sensor is at the y-pipe.
Old Jan 23, 2003 | 08:11 AM
redmaxpa007's Avatar
i SeE what you did therE
Firsts time cali spec owned anything... But i am still proud!!
Old Jan 23, 2003 | 08:18 AM
ejj's Avatar
ejj
Warpspeed will make a straight pipe however you want.
I have a 99 Fed Spec, but don't have a hole in my apexi ws b-pipe for my rear O2 sensor. I had them put a hole for the sensor in the straight pipe. No problems!
Old Jan 23, 2003 | 12:34 PM
breaux124's Avatar
But you guys only really have 1/2 a Y-pipe.
Old Jan 23, 2003 | 05:06 PM
we have a 7/8th of a y pipe...
i have a stillen 2 piece design one so it is close.. (and i plan on being non cali-spec by summer..
shilov
Feb 19, 2024 09:40 PM
lrb6805
Sep 17, 2015 04:49 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Violator
Sep 9, 2015 10:14 AM
