brighter corners w/o re-wiring!!!!!
Old Jan 6, 2001 | 07:48 AM
1HOTMAX's Avatar
has anyone atempt this and it worked??/ use a 1156 bulb and file one nib and use this bulb to replace the 1157 oem to make the corner brighter????
Old Jan 6, 2001 | 07:52 AM
Nine7Max's Avatar
nope
i havnt tried, i heard something about aluminum foil too any other ways?
Old Jan 6, 2001 | 09:48 AM
teejnut's Avatar
yeah i've done it. i used a grinder to grind away the one nibble. worked fine. i've had it in for a few months.
Old Jan 6, 2001 | 02:36 PM
benny's Avatar
I have done this, it works great. i have been posting this solution for awhile hope to make it simple without soldering. quick and easy, also easy to return to stock. just a lightbulb change.
Old Jan 6, 2001 | 02:43 PM
BippuBenji's Avatar
I've done it that way and it is a great solution. I used my mom's nail clipper to remove the the other tab.
Old Jan 6, 2001 | 03:19 PM
Southpaw17
hey can u email me how to do it please. thanx
DEBO
Old Jan 6, 2001 | 04:21 PM
Jimp
Could you email me the info also? Thanks a bunch
Old Jan 6, 2001 | 06:24 PM
MICHAELCORY's Avatar
could you also email me that info or just post it om this forum. Thanks.
Old Jan 6, 2001 | 07:49 PM
benny's Avatar
simple and fast
purchase or used the tail light bulbs(1156) after you clear it. (1997-1999) just take a file or used a grinder to remove one of the nibble. put the light bulb into the corner light socket with the nibble in the lower side socket. don't worry about fitting it in wrong, there is only one to fit it for the bulb to light up. the 1156 is a brighter bulb. so the corner will be brighter and match the headlight. once you compare the 1156 to 1157 bulb side by side, you will understand these instructions better.
good luck.
Old Jan 6, 2001 | 11:09 PM
maximumsportZ's Avatar
Lives in a 350Z
ok so how could i make my clear corner on my bumpers brighter??
Old Jan 6, 2001 | 11:25 PM
emax02's Avatar
I am putting H4 piaa Plasmas in my cornor lights,
just a little grinding and glueing and your golden haha,I think it would probably over heat in a max's cornor light though because unlike a I30 they are always on.Just a Idea.
Old Jan 7, 2001 | 12:07 AM
ny96max's Avatar
I tried the "shaving one nibble off technique" and it worked for half the night, then boom!! all my corners and tails went out. I checked the fuse and she blew. So i guess back to the regular voltage for me. Thanks anyway guys for the info, very easy to-do mod!! I think eventrually it will leave some kind of burn mark on the lense cause they got super hot and it was like 10o out tonight. Just my 2cents.
Old Jan 7, 2001 | 12:21 AM
BrianV's Avatar
The stock bulb is dual filiment. If you take the stock bulb out, cut one nub off, put it in backwards it will do the same thing. Looks VERY nice.
Old Jan 7, 2001 | 02:03 AM
Maxima97GLE's Avatar
Hey Anthony... Mike burned out one of his too... but I'm still good... but watch I bet tommorrow they'll burn out too. Other than that... they look hott
Old Jan 7, 2001 | 07:06 AM
Ants97SE's Avatar
Simple fix on that, change the fuse for the taillights relay to a 7.5 amp fuse instead of the 5 amp. That will fix it.
Old Jan 7, 2001 | 08:42 AM
Lives in a 350Z
damn after hearing about a fuse blow out and it might leave burn marks i'm having second thoughts on doing this
Old Jan 7, 2001 | 12:44 PM
krosenb's Avatar
clearance lights
Great stuff everyone but, how come no one seems offers a superwhite 1157 27/8(w) or a superwhite 27(w) 1156 bulb? I just want to match the color of my PIAA 9004's and H3 bulbs. It seems so simple but I just can't seem to find the right replacement part. If anyone knows were to find them online it would be greatly appreciated.
Old Jan 7, 2001 | 02:09 PM
tgonza1057
no no no no no
when i put my 1156 on i just bent the socket so i could fit it in its nice and snug and if i want to go back to stock i got no problems ive had mine in for 5 months no blow outs no problem
Blkkn8
Sep 22, 2015 06:37 PM
bumpypickle
Sep 20, 2015 08:22 AM
