tick tick tick sound in car
-if the noise occurs when you turn the ignition switch from the on to the start position, then it could be a defective starter solenoid (if the starter's not spinning the engine)
-if the noise occurs after the engine turns over and before it warms up (esp. if you're getting the Arctic blast much of the nation is, now), then it could be a little extra valve noise because of the cold conditions.
Otherwise, I agree. It's a bomb. Leave that one to a professional.
-Matt
Originally posted by Man74
Car won't start at all..He just got an automatic starter and it won't start using the starter or using he's keys....Just makes that noise.....
A new starter motor and solenoid can be purchased together, or just a solenoid can be bought, and the starter motor reconditioned.
See: www.motorvate.ca (click on the link for "Interesting Fixes," then "Starter Noise Fix") Here, you can learn how to recondition the starter motor.
Just to be sure everything else is in working order, clean battery posts and connections, re-secure + & - leads, loosen then tighten electrical leads on the starter motor itself, loosen and tighten all grounds in the engine bay; test the battery.
NO NO NO NO...the automatic starter is bad...Nothing to do with the starter on the car at all. If its clicking and not starting with the fob thing, then its not making connection or its defective and needs to be replaced. check it out
-matt
-matt
-matt
-matt
-matt
-matt
As already mentioned, the solenoid needs to be replaced. You can also just replace the entire starter. Shouldn't take you more than 45 minutes to do it yourself. Very easy fix. Post if you need help and I'll answer any questions that I can.
Justin
Originally posted by JdawgX
you need to read his entire post. It states that his car won't start using the fob or the keys.
Justin
Justin
Clicking can be a relay sound, but clicking from a relay is usually a good sign - generally it means the relay is working. Also, a bad auto-starter relay wouldn't explain a non-start condition with the ignition key.
Btw, if this turns out to be a wiring problem resulting from a professional install job (auto-starter), get whomever did the work to fix it.
Good luck!
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
