please help with ECU trouble code....
Old Jan 6, 2001 | 03:01 PM
roggie93ser96se's Avatar
could someone please tell me what ECU trouble code 0901 is. Thank you very much in advance...
Old Jan 6, 2001 | 03:12 PM
Daniel B. Martin's Avatar
Diagnostic Trouble Codes may be found on-line at:
http://web2.airmail.net/scutchen/max_faq/engcodes1.gif
http://web2.airmail.net/scutchen/max_faq/engcodes2.gif
DTC 0901 is "Front Oxygen Sensor - right bank". The voltage signal sent to the Engine Control Module is outside the normal range. The front Oxygen Sensor is bad or there is a problem with the associated electrical harness and connector.
Old Jan 6, 2001 | 03:19 PM
thanks..
thanks alot Daniel, I've seen that page w/ the codes on it before but with my web-tv I can't read them and don't have the ability to zoom in, by the way where are you from Daniel...
Old Jan 7, 2001 | 07:28 AM
dch95's Avatar
Also FYI, the sensor also goes off when it picks up bad readings out of the normal range. Although I understand that the sensors on these cars tend to go out (so far so good on mine) I ended up changing spark plugs on mine which got rid of my check engine for oxygen sensor. The old plugs were burning the gases at a rate out of the norm that the O2 sensor considered bad there by telling the computer something was wrong.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
zmcneely13
Sep 26, 2015 02:26 PM
Socalstillen
Sep 20, 2015 11:46 PM
