odometer/tripometer not working - just dunno
Old Jan 26, 2003 | 06:57 AM
mrbill's Avatar
and back to square one. Have a 96 max 5 speed. About one month ago the odometer/tripometer stopped working (tach and speedometer work fine). About two weeks ago the CEL came on, but it is finding an unrelated problem (0705 EVAP Control Sensor..plenty of info in previous posts). So, is it possible the speed sensor is bad if the CEL does not identify a problem "and" if the speedometer still works? Any ideas or with what may cause just the speedometer/tripometer to not work?
Thanks...again....
Old Jan 26, 2003 | 07:49 AM
Ramius83
Man, I don't know what to tell you. When my speed sensor went bad, my speedo, odometer, and tripometer quit working. So that was a definite sign that the speed sensor was shot. But in your case, I absolutely have no clue. This may seem repetitive, but have you checked ALL your fuses inside the cabin and in the engine bay? Also, have you taken your cluster out lately? I would take it out and inspect all steel wires on that BACK of the cluster and on the harness.
Old Jan 26, 2003 | 08:11 AM
cbr2's Avatar
i have the same issue...
it is a problem inside the speedo box i think...
one of the gears have worn out.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
