Cooalnt leak
Old Jan 26, 2003 | 09:53 AM
blakkrob's Avatar
Cooalnt leak
I have searched and I am confused . I have a coolant leak and I thought it was the water pump. I read that if the water pump is leaking you'll have water in the oil. Well I don't have any water in my oil. I tightened all my hose clamps and thermostat housing. The leak is coming from behind the A/c compressor below the alternator. I have taken my reservoir ut and checked it. I have taken my radiator cap off and crank the car, that test was fine also. I even took it to the dealer and paid $80 and they couldn't find the leak. Seems that after I have driven the car the leak vanishes. My car has never overheated the coolant level doesn't seem to change, well no that much. Can anyone help me I don't wanna pay for a new water pump and still have this problem.
Old Jan 26, 2003 | 10:09 AM
matty's Avatar
If you live in a cold climate its ok to get a small leak over night because in the cold the rubber hoses expand and dont seal all that good on the engine or radiator, after you drive it around during the day the rubber contracts onto the conections and is fine..Nissan probably checked the car after they had it warmed up. Make sure the level doesnt go anywhere cause engine damage can occur
-matt
Old Jan 26, 2003 | 04:06 PM
blakkrob's Avatar
Ok! I am in Ga and the weather has been relatively cooler thatn the norm. I will keep an eye on it though.
-matt
Old Jan 27, 2003 | 05:52 AM
njmaxseltd's Avatar
Those people who live up in Canada must go through a lot of Antifreeze.
Old Jan 27, 2003 | 08:31 AM
rmb's Avatar
rmb
If you live in a cold climate its ok to get a small leak over night because in the cold the rubber hoses expand and dont seal all that good on the engine or radiator..... blah blah
-matt
That is total BS. If it leaks then the hose and/or clamp need to be replaced.
It sounds like your water pump is going. The seals go slowly though so it might be awhile. I'd replace it just to be sure... How many miles?
-RMB
Old Jan 29, 2003 | 09:47 AM
macinmaxima95's Avatar
I had a similar problem with my 95 max. I had ripped the engine apart and found that the leak was coming from the timing chain cover. After researching it i found that the only thing behind the timing cover is the water pump. I took mine to a radiator shop to get it fixed because the space to do it was way to small for me. It cost me about $300. Now it doesnt leak.
Old Jan 29, 2003 | 12:05 PM
NmexMAX's Avatar
dot dot dot ...
100% same thing happened to me.
Old Jan 29, 2003 | 12:12 PM
RedbeardMax
I thought maximas were leak-proof...made in Japan...reliable as ever...top of line Japanese sport sedan...
We've got to complain to Nissan in group action.
Who wanna call Gary Martin & Associates for group settlement VS Nissan for making our car so susceptable to breakdowns?
Old Jan 29, 2003 | 12:16 PM
RedbeardMax
Blakkrob, you survived!
You survived the GA winter!!!
I'm another victim of Nissan hope to c u on next ATL meet.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
followthadollar
Sep 17, 2015 06:31 PM
