Cruise Control...?
Old Jan 27, 2003 | 01:10 PM
MaximaMoJo's Avatar
Cruise Control...?
My cruise control shuts off when I turn on my turn signal. This is really annoying and have no idea what is causing this problem. I tried replacing the ground with no avail. Does anyone have any possible idea what is causing this or where I can look to find an answer. Any input would be much appreciated!
Old Jan 27, 2003 | 07:21 PM
MaximaMoJo's Avatar
Bump...
Old Jan 28, 2003 | 12:48 PM
MaximaMoJo's Avatar
Bump...
Old Jan 28, 2003 | 01:39 PM
s2cmpugh's Avatar
well that is wierd, ima try to take a stab at it. ok first i would pull part the setterin column covers and check ALL connections. if necessarey remove the turn signal stalk and check that as well. also check connections on the cruise buttons on the steering wheel.
hmmmmmmmm my guess is that it you might be accidnetly shorting out the cruise when your move the stalk so check alllllll wiring in there, and if necessary replace the stalk.
this is just a guess though since no one else has helped you out yet
Old Jan 29, 2003 | 06:34 AM
MaximaMoJo's Avatar
Thanks, I will try that when I have some free time and it gets warmer. Cold here in Indiana! Thanks Again
Old Jan 29, 2003 | 07:04 AM
s2cmpugh's Avatar
no prob man
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
schmellyfart
Sep 25, 2015 04:47 PM
jchronis2552
Sep 21, 2015 05:52 AM
Maximeltman
Aug 31, 2015 01:01 PM
