Keep blowing headlights
Old Jan 27, 2003 | 06:45 PM
Parsec's Avatar
I'm on my 4th set of headlights in the past 6 months.. blew out one sylvania, one nokya, and then 2 nokyas blew out on me within minutes of each other. What could be wrong?
Old Jan 27, 2003 | 06:49 PM
Dev's Avatar
Dev
Re: Keep blowing headlights
don't touch the bulbs; it shortens the bulbs life from the oil on your hands.
if you happen to touch it, clean the bulbs with alcohol (i forget which type)
Old Jan 27, 2003 | 08:56 PM
Parsec's Avatar
Yeah, I know to never touch the bulb w/my hands. Looks like the problem is getting worse or has changed. Tonight I (well, my dad, not me, since the car isn't here), put in another set of headlights after the old ones blew out again and he says it wouldn't even turn on anymore. I guess there's an electrical problem of some sort ... and he won't touch it if that's the case. Grr..
Old Jan 27, 2003 | 09:07 PM
(_8*(l)Homer's Avatar
I think nokyas are high wattage (80-100) If so, you fried your headlight harness. Get an aftermarket 9004 harness from e-bay or something. THey aren't too hard to install, I have seen write-ups on here how to install.
No bulbs you put in the existing harness are going to work very long.
My 2¢
(_8*(l)
Old Jan 27, 2003 | 09:16 PM
96BLUMAX's Avatar
Either up the amps on the fuse for the headlights or there is a seriour short.
Old Jan 27, 2003 | 09:17 PM
ivelweyz
My 2¢
(_8*(l)
Check the spelling under your pic. Oh and lose the crappy aftermarket fogs. You got too many lights...
Old Jan 28, 2003 | 12:04 AM
JsL's Avatar
JsL
I am pretty sure that it is moisture in your housing causing your bulbs to blow.
Old Jan 28, 2003 | 05:50 AM
njmaxseltd's Avatar
Your running 80/100 Watt bulbs and you've probably damaged the socket. Take a good look at the contacts in the socket, there probably all burned from to much current draw. The burnt connections aren't letting current flow anymore.
If there not completely melted, you can clean them up with WD-40 and a thin nail file. The treat them with dielectric grease so it doesn't happen again.
Old Jan 30, 2003 | 05:41 AM
macinmaxima95's Avatar
Check out the sockets. I had the same problem and found that the bulbs were actually melting the socket. If they are melting it is a $3 fix. I havent had the problem since.
Old Jan 30, 2003 | 10:48 AM
jbreit's Avatar
check your battery voltage while the car is running...your voltage regulator in the alternator could be bad and letting the voltage get too high....voltage should be 13.8-14.4 ish
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Oct 28, 2019 10:58 PM
Noela
Sep 26, 2015 08:22 AM
