If you replaced your Axle / CV Boot help me.
Old Jan 29, 2003 | 09:22 PM
maximumsportZ's Avatar
Lives in a 350Z
post here if u did so yourself.
Thanks.
Old Jan 29, 2003 | 09:28 PM
Nismo's Avatar
at school but not on the max. what was your question?
Old Jan 29, 2003 | 10:53 PM
Che's Avatar
Che
Re: If you replaced your Axle / CV Boot help me.
Thanks.
I just replaced my passenger axle and knuckle.....what do you need to know?
Old Jan 29, 2003 | 11:05 PM
mtrai760's Avatar
'Trynna' is not a word
Takes 30-40 minutes. You need an 1 1/2 inch socket and good breaker bar to remove the axle nut, an 18mm and 19mm to remove the lower strut bolts, and a 19mm to remove the tie-rod nut, plus a tierod removal tool. Make sure you have a torque wrench and cotter keys to put everything back together correctly. It's an easy job, deffinetly wouldn't pay anyone to do it.
Old Jan 29, 2003 | 11:38 PM
pezking4's Avatar
Did 'em on a 95 GLE
Old Jan 30, 2003 | 12:28 AM
ladeesman's Avatar
^MY 95 GLE
Old Jan 30, 2003 | 02:22 AM
Sprint's Avatar
the axle nut is 36mm
Old Jan 30, 2003 | 02:40 AM
ladeesman's Avatar
Try to find one from a friend...it cost like $8.00....and btw....its a Biotch to get off....took a homemade 4 foot breaker bar and all i had to get mine off....
Old Jan 30, 2003 | 03:19 AM
Maxxxima's Avatar
If the boots are completely ripped around on the outer cv boot, someone told me that you could take the ball bearing apart, clean all the grease out and clean the inside really well, then grease everything back up put it back together and put a new boot on. Is this true because mine are completely ripped around on both sides. I checked out the price on raxles.com for new axles, and they are really $$$. Also, I live in Hawaii and raxles quoted me $85 to ship. Thanks.
Old Jan 30, 2003 | 03:35 AM
pezking4's Avatar
How long have your boots been ripped? Raxles should be $300, but they are really good quality, keep that in mind.
Old Jan 30, 2003 | 06:28 AM
TitleistPrto's Avatar
I am doing both of my axles and joints this weekend. Any tips before we get started? Any troubles that anyone else had?
Old Jan 30, 2003 | 07:17 AM
marcdown20's Avatar
if u have any access to air tools... this is one of those jobs that it helps greatly to get that big bolt off at the end of your axle... job is an easy 30 mins flat then...
mike
Old Jan 30, 2003 | 07:28 AM
Lives in a 350Z
Thanks to all for the tips.
Do you have to drain the gear oil? I was reading http://www.motorvate.ca/auto/maxima/...andr-part1.htm and it mentioned it.
BTW I'm auto.
Old Jan 30, 2003 | 07:40 AM
Sprint's Avatar
i don't think so.. but i had the tranny out when i did it and i was sleeping last night when you messaged me
Old Jan 30, 2003 | 07:47 AM
pezking4's Avatar
BTW I'm auto.
From my experience thus far, autos do not have to drain.
Old Jan 30, 2003 | 12:13 PM
Maxima95Tuner
Autos dont HAVE to drain, but the fluid will spill out in pretty large quantities when everything is removed. I've replaced quite a few axles with my friends, so IM me if anyone needs help.
Old Jan 30, 2003 | 01:07 PM
ladeesman's Avatar
MY fluid didn't come out at all....found it kinda odd...anyway..you should go with Raxles..its around $300 vs. $1300 that Nissan wants. That boot replacement method works but rarely...if you leave on bit of dirt in there it is going to contiute to make it worse...I joint could already be damaged especially if its ripped all the way around. Get new axles, period.
boomerbrian
Nov 8, 2015 05:10 PM
Starrider
Sep 17, 2015 07:26 AM
PH98I30
Aug 20, 2015 04:25 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
