dim headlights
Old Feb 2, 2003 | 04:26 AM
woodogga's Avatar
dim headlights
Another question for you guys....... a while back, I had to put those high heat harnesses for my xenon headlamps. Well, after they were installed, my headlights were never as bright. Now my 'brights' are where my 'lows' used to be. I don't understand this. Also, my 'brights' indicator light on my dash is always lit up now; dimmer when my low beams are on, and then bright when my highbeams are on. Before I had the harnesses installed, this light only came on when my highbeams were on. Is my electrical system screwed. I have since replaced my xenon with OEM lights, as the xenon kept blowing out after 6 months or so. Any advice anyone can give is greatly appreciated! Thanks.....
Old Feb 2, 2003 | 04:33 AM
98maxsel's Avatar
you sure you installed it right? shouldn't do that if everything went right. go back and check everything out.
Old Feb 2, 2003 | 08:34 AM
Hed5150
I RED SOMEWHERE THAT WHEN INSTALLING A HID KIT. YOU CAN LOOSE THE EFFECT OF YOUR HIGH BEAMS. I KNOW POEPLE DO IT AND IT WORKS, BUT I JUST READ THAT SOMEWHERE. (CUSTOMMAXIMA.COM) I THINK
Old Feb 2, 2003 | 10:34 AM
Kashoggio's Avatar
lol you installed them wrong, check your wiring
Old Feb 2, 2003 | 11:33 AM
gepetto's Avatar
Sounds more like a harness issue to me. Did you buy an upgraded wiring harness?
gavin68
Sep 18, 2021 12:36 PM
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
