DTC Self Diag / Results
My check engine light came up on my 95 Maxima with 90K miles. I took it to the dealer and he showed me a DTC results report. it showed something like this.
SELF DIAG RESULTS
DTC RESULTS TIME
KNOCK SENSOR 0
[P0325]
HO2S1 7
[P0130]
PURG VOL CONT/V 0
[P0443]
After looking at this forum and reading several articles I decided that the O2 sensor is bad and I asked them to replace it. (of caurse the dealer said I have to replace all 3 and gave me an estimate for $1.4K)
When I went to get the car I noticed that the report had another portion (Dealer did not show me this part.. suprise!!!) to it and had the following additional information.
( I asked the clerk to make a copy)
DTC RESULTS
PURG VOLUME CONT/V
[P0443]
System Data
FUEL SYS-B1 Mode5
FUEL SYS-B2 Mode5
CAL/LD VALUE 0%
COOLANT TEMP 57 F
........ Rest is all 100%
My questions are,
1) was my O2 sensor bad?
2) do I have a bad PVC too?
One more thing is that when I start for the 1st time in the morning I have to keep my foot on the pedal for 2 sec. if not it tends to die. After 2 sec.s I can take my foot off the pedal and it runs at idle speed without a problem.
Thanks in advance
Pora Mola
SELF DIAG RESULTS
DTC RESULTS TIME
KNOCK SENSOR 0
[P0325]
HO2S1 7
[P0130]
PURG VOL CONT/V 0
[P0443]
DTC RESULTS
PURG VOLUME CONT/V
[P0443]
System Data
FUEL SYS-B1 Mode5
FUEL SYS-B2 Mode5
CAL/LD VALUE 0%
COOLANT TEMP 57 F
My questions are,
Thanks in advance
Pora Mola
Correction.... The formatting got messed up for the 1st part of the results. Here it is again
SELF DIAG RESULTS
DTC RESULTS ........TIME
KNOCK SENSOR......... 0
[P0325]
HO2S1 ............... 7
[P0130]
PURG VOL CONT/V...... 0
[P0443]
SELF DIAG RESULTS
[P0325]
[P0130]
[P0443]
Replace your PCV Valve yourself - cost = $5
Check your plugs and coils
I'm willing to bet it's th PCV however - do it yourself and reset the computer annd save over 1.4k!!
I hate dealerships - they see that codes go off and routinely replace the sensors. Sensors throw codes for a reason!! It doesn't mean they are bad, it's usually indicative of something else (like a clogged PCV)
I actually did a full tune up
-new platinum plugs
-cleaned TB
-new fuel filter/air filter
I was tald the PVC valve was cleaned but I am having doubts now... why whould he clean it if it was that cheap!!!
I am going to get a reapir-manual and do it myself..
Any good recomendations for a repair-manual?
Thanks for the advice...
-new platinum plugs
-cleaned TB
-new platinum plugs
-cleaned TB
-new platinum plugs
-cleaned TB
A set of Panel Poppers (buy at your local Schucks/Kragen) is an awesome tool for popping the PCV out of it's hard to reach spot.
IanS
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
pktaske
Sep 4, 2015 08:40 AM
