vacum pressure test. help
Old Feb 3, 2003 | 09:04 PM
andreyyy's Avatar
hi guys i need a help, i want do the vacum pressure test but i couldn't finde the place to plug it in , i looked in the manual but the diagram is on the mercury engine so if anyone know about it ,please help.
thanks.
Old Feb 3, 2003 | 09:51 PM
andreyyy's Avatar
Old Feb 3, 2003 | 10:35 PM
White96MaxSE's Avatar
Originally posted by andreyyy
I'm watching this thread to see what anybody might say about it.
I don't know the answer, but I'm interested in the topic.
White96MaxSE
Old Feb 4, 2003 | 02:10 PM
andreyyy's Avatar
please anyone ?????
Old Feb 4, 2003 | 02:47 PM
FLO_BOY's Avatar
don't quote me on it..
but I assumed that to test vaccuum you simply pick a spot,
disconnect the hose and test that hose...if it checks out,
go onto the next hose...and so on.
From what you're describing, it would seem that you're looking
for somewhere to "plug in"...and I'm not sure if that's how these
things work.
hope this helps,
FLO_BOY
Old Feb 4, 2003 | 03:15 PM
xHypex's Avatar
If you're doing a vacuum test, the easiest place to tap into is the fuel pressure regulator.
Here's a picture of the FPR, which I tapped to get vacuum to activate my VI.
The FPR is near the knock sensor just down and to the left of the throttle body. Your readings should be somewhere in the neighborhood of 22 in/Hg of Mercury if everything is ok. You will get less if something is leaking.
-hype
Old Feb 4, 2003 | 06:49 PM
please anyone ?????
Andreyyy;
That sounds like a good place to start taking vacuum readings.
xHypex says the Fuel Pressure Regulator.
I do know that a mechanic friend of mine once did a fuel system cleanout with a Sun machine and as part of the setup we learned from the Haynes Manual that 22 mm of Mercury would be either a healthy engine or a new engine.
We thought it was pretty cool that my Max with 160,000 mile on it read at 18 mm of Mercury (mm/HG) before the cleanup procedure was ran and 20 mm of Mercury after the test was completed.
This seemed to indicate a nice improvement of about 9 percent increase due to the fuel system cleanup.
We also thought that was interesting since I had always ran Amoco Ultimate since the car was new, and periodically used the Techron Concentrate to clean the fuel injectors.
Finally, We didn't think it was too bad for a car with that kind of mileage since it was so close to the manufacuter's specifications for a new or healthy engine.
We also didn't think we had any vacuum leaks.
White96MaxSE
Old Feb 4, 2003 | 10:17 PM
andreyyy's Avatar
thanks guys
Old Feb 5, 2003 | 04:19 AM
Sir. Max's Avatar
Re: vacum pressure test. help
thanks.
I just did a vaccum check a couple of weeks ago. The Haynes Manual only showed where to tap in for a 3rd gen. I just used the vaccum schematic thats under the hood to figure out places to connect my gauge. Turns out that T'ing into the charcoal cannister line was easiest for me. Pic below just shows the T connection.
I got a reading of 21 in-Hg. My bad, if the pic dosen't work.
http://www.ImageHosting.com/images/...Vaccumchk32.jpg
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
msellas
Sep 23, 2015 09:16 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
