Question about Front Strut Bearing !
I just want to know if a worn Front Strut Bearing may lead to unusual noises in the front suspension. I just changed the front struts and strut mounts in my '96 I30 and the car still make a noise that I can feel in the upper area of the struts, near the strut mount, when hitting potholes on the road, this noise is driving me nuts, somebody told me that may be the Strut Bearing were worn, but I don't really think this will remedy my situation, what do you think ?
Re: Question about Front Strut Bearing !
If the bearing isn't holding the upper spring perch securely onto the strut mount or has been installed upside down and damaged, it will cause a clunky suspension.
The part is very critical to keep everything together and rotating smoothly. The tiny lip on the bearing is the only thing holding the upper spring perch in place against the strut mount. If it's worn slightly, the spring perch can move slightly causing unwanted noises. The bearing is only 20 bucks from Nissan and I highly recommend changing it every time you change your suspension. It's good cheap insurance for a quiet suspension setup.
The noise is present only when hitting potholes on the road or in uneven road, it's a kind of "Popping" sound, the sound is not present when turning just when hitting potholes, and yes the Strut Mounts were replaced with KYB Strut Mounts along with the KYB GR-2 Struts ! So I'm thinking that the KYB strut mounts are the problem here, right?
It's hard to tell if just the mount would be at fault here. It's really an entire assembly you have to look at. The upper spring perch, bearing and strut mount all work together to keep things lined up and rotating smoothly. Once things are out of wack, or the clocking or spring angle is off a bit, the suspension usually tells you by making noise.
so would this help my problem out?? as i have this kinda like small popping noise, on a totally factory suspenion. It only comes from the front and it seems to happen more on small imperfectons in the road??
any ideas?
thanks
Cris
any ideas?
thanks
Cris
MaxStock
08-14-2015 10:01 PM
Greenmaxspeed
08-08-2015 12:39 PM
laparka66
08-06-2015 09:36 AM
