peeps with Injen intake install help!!!
Old Feb 5, 2003 | 08:03 PM
RI-Max's Avatar
hey guys i just got a used injen intake for 150.00. it was off a 99 max se. where do u guys blot it down on the lower hose casue their a bracket their? how did u guys hook up the sensors?? Temp&MAF. the temp sensor is different (the one that came with the intake) then the factory one? the harness doing fit each other. how u get the wire of the sensor 2 reach casue i had 2 flip my MAF upside down 2 reach. anyone have any tips
(no CEL came on)
thanx jeff
ps. its loud too
Old Feb 6, 2003 | 05:38 AM
z30maxima's Avatar
Re: peeps with Injen intake install help!!!
Yeah, I also had this problem, only thing is...I still have this problem with my air temp. sensor...I searched and searched=no luck!!! My guess on this problem would be to get a 97-99 air temp sensor and splice the wires. Keep in mind though, I haven't had the time of day to even do this, just a suggestion. I keep getting CEL and it's related directly to the air temp sensor. Also, I read up on in, and I am sacrificing power and gas mileage....Now I might get his done and post about it...
Old Feb 6, 2003 | 12:30 PM
BBaker025's Avatar
I had a hard time doing these things too, I installed my intake monday. In ur stock scoop u take the air intake temp sensor and rubber gromit pull them out. Put them in ur new intake and it will work. You will see a metal resistor on the fender wall, unscrew the 2 screws and the MAF sensor will reach the plug. Watch out because I put my intake in and the fan was rubbing with the filter.
Old Feb 6, 2003 | 12:44 PM
redmaxpa007's Avatar
i SeE what you did therE
did any of you get directions?
the instructions i got spelled out everything and what to move and where to move them.. i have no problems.. i will see if i can scan the directions ..
Old Feb 6, 2003 | 02:36 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
ditto.....confusing directions and sh1tty black and white pictures, but directions nonetheless
Old Feb 6, 2003 | 04:07 PM
Tifosi's Avatar
Absolutely. it's bad pictures and confusing directions. But if you spend just a little time reading it, it's all good. I opened my box up and said, "Ah, this should be quick and simple, probably don't need the instructions!". Then found out I really had to read the instructions first. The only encounter I have is the black box underneath the battery tray, I needed to take that out too, it didn't say that in my directions. Took hour and half total with a casted right wrist, no bad at all.
Tifosi
Old Feb 6, 2003 | 04:37 PM
RI-Max's Avatar
omg i think i put my MAF Sensor on backwards the harness that u clip in it on the engine side. i seen on your sig Tifosi that i didn't do it right (your is on the fender side). would this casue a starting problem????
i got no CEL light yet.
Old Feb 7, 2003 | 10:43 AM
Don't worry, i broke my MAF sensor 2 days before i put my intake on....No big deal.
definitely. The direcions say nothing about the bottom part of the airbox. This was the first thing i did to the car myself, but as long as you take your time and pay attention, you really can't go wrong.
Old Feb 19, 2003 | 06:43 PM
z30maxima's Avatar
anyone have a 95-96 here? b/c my air temp sensor is a small oval plate with to mounting screws. No rubber grommet an no way to " pull it out" this has been geting to me ever since I did the install about 4 months ago. just wondering if it cold be fixed...
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
Johnny9595
Sep 3, 2015 05:18 AM
