Please help with JWT pop charger !!!
Old Jan 8, 2001 | 04:28 AM
RKS's Avatar
RKS
I have a 95 SE and just installed the JWT pop charger along with new spark plugs (NGK) yesterday and now under hard accelaration the car sputters and knocks. It feels like it's going to die unless I let off the gas. I think I smell the cat converter also.
Could this be caused by the placement of the small sensor (temp?) that was located INSIDE the original airbox? It is currently attached to one of the bolts holding the pop charger in place. Should I place the sensor INSIDE the cone?
I sure somebody else has experienced and resolved this issue!!!
Any help/suggestions are greatly appreciated. TIA
RKS
[Edited by RKS on 01-08-2001 at 10:01 AM]
Old Jan 8, 2001 | 07:59 AM
SmoothMax's Avatar
OG
When I installed my popcharger, I drilled a hole into the base of the filter itself and screwed the temp sensor into the filter. I don't think not placing the sensor directly into the filter would cause this, but then again I'm not an expert. Try putting your stock air box back on and see if it still does it.
Old Jan 8, 2001 | 08:15 AM
I had attached the sensor to the outside of the pop charger as well and had no problems with it. Did you disconnect the battery to reset the computer after installing the pop charger? Also, I would check the spark plugs/coils for some loose connections. Good luck and let us know!
Old Jan 8, 2001 | 08:22 AM
RKS's Avatar
RKS
Thanks for the info guys.
I didn't realize that I had to reset the computer. I'll try that tonight along with rechecking the plugs. If all else fails I'll go back to the OEM airbox until I can get the Stillen version or CAI.
Old Jan 8, 2001 | 08:33 AM
rockymtnmax
Don't know if this will help but I've seen it mentioned....
Did you disconnect a battery terminal for 2 hours to reset your ECU???
Let me know,E
Old Jan 8, 2001 | 08:48 AM
rockymtnmax
oops I guess it was already mentioned.
But let us know how it works and sounds because I getting one for my 95 SE.
Thanks, E
Old Jan 8, 2001 | 08:52 AM
Washington DC Maxima's Avatar
I'm almost sure that it's the plugs you installed-->>
not the JWT... You need to check your caps or retorque and/or regap the plugs..
Old Jan 8, 2001 | 09:03 AM
Victim64's Avatar
Re: I'm almost sure that it's the plugs you installed-->>
I strongly agree with this. Unless you used a hammer to install your JWT intake, I don't think that is the problem!!!
Old Jan 8, 2001 | 11:35 AM
RKS's Avatar
RKS
Thanks to you guys I got it going. I must not have snapped the wire to the coil plug on the spark plug all the way and the connector was loose. Runs like a champ once again. Thanks guys.
Old Jan 8, 2001 | 12:16 PM
ChiTown Max's Avatar
That's good to hear. I had that problem after I took my car in for a tune-up, and it was the same thing--the mechanic didn't plug one of the coils in tight....
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Mahmuth
Sep 25, 2015 10:08 AM
