E-brake Light Staying On??
Old Feb 9, 2003 | 10:07 AM
infinitiblast's Avatar
When its cold in the morning or when its cold period if I have my ebrake on then let it down. The light still stays on..after it warms up it goes away. Whats up with this?
Old Feb 9, 2003 | 10:40 AM
Soul Fly
hmm. i've got a 3rd gen...almost the same problem. i always put my e-brake up...(even tho i have a/t) but right when the cold weather started to come about...it wont go off. I'm thinking it could be shorted out? or i need new rear brakes?
I should get it checked out
Old Feb 9, 2003 | 10:41 AM
«§»Craig B«§»'s Avatar
that dash light is not just for the parking brake, it also comes on when you're low on brake fluid
check that NOW
what are you waiting for? GO
Old Feb 9, 2003 | 10:43 AM
I'm going I'm going!
Old Feb 9, 2003 | 12:11 PM
Lushka16's Avatar
This same thing happens to me too, but only in the deepest cold. I took off my back tire to take a look, and it turns out (at least in my car) that the cable that engages the break doesn't fully disengage, but not to the point that my breaks are still on, just to the point that the light doesn't shut off until things warm up. I did check my fluid levels btw, and it seemed fine
-Elia
Old Feb 9, 2003 | 12:36 PM
TheNip73's Avatar
Not to be ****, but the handbrake is refered to as the PARKING brake. It is not an emergency brake. It is designed to be engaged when parking, hence the name. Sorry, just a pet peeve of mine
Old Feb 9, 2003 | 04:19 PM
Soul Fly
check that NOW
lol - i gota get some $ first.
Old Feb 9, 2003 | 04:41 PM
Miasma's Avatar
so what brake do YOU use when your hydraulic brakes go out? i use my emergency brakes.
Old Feb 9, 2003 | 04:54 PM
TheNip73's Avatar
I would be using my parking brake in an emergency situation. To get really technical I would actually be using my rear brakes... but enough nonsense. The term emergency brake just bothers me. Maybe I should try to get over it, or I may go insane, they way people in this forum are
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
pktaske
Sep 4, 2015 08:40 AM
