CV Joint and brake ??
Old Feb 10, 2003 | 03:37 PM
Kevlo911's Avatar
Kevlo for President
When i was gettting my alignment done they said i need to get my cv joint replaced, i was hearing a tick tick tick sound too
the noise is comming from the passenger side, so what part do i need to replace inner or outer cv joint also should i replace the drivers side too, or should that be good
Where is a good place to buy it online
Brakes need to be replaced in the front, what are some good, notbad dusting front brake pads that i can buy online
thnx
Old Feb 10, 2003 | 04:49 PM
njmaxseltd's Avatar
The guy shouldn't have done the alignment at that point. When they replace the axel, your gonna need another alignment. If your alignment guy was a straight shooter, he should have told you that. The suspension has to be disconnected at the hub. Once you do that you throw off the alignment.
Old Feb 10, 2003 | 05:15 PM
JPMax's Avatar
What's next!?..
CV joint: Need to replace the whole half-axle www.raxles.com If you can afford it, do both sides.
Brake pads: Raybestos QS ceramic pads. They come with their own self adhesive shims. www.wdautoparts.com
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
