Brake Pads?
Brake Pads?
Hey guys, what are some good brake pads to go along with the stock rotors? I want to upgrade the brakes a little, but I don't want to spend the money on all new rotors. How much can upgraded pads (without rotors) help? Also, I have always had squeaky brakes (never went away), so would getting new pads stop this? Or will I HAVE to replace the rotors?
Re: Brake Pads?
you should see improvements with just upgrading front pads, the cross drilled/slotted rotors will definately help when u do lots of braking in a short period of time by keeping your contact surfaces cooler....
the brands for the pads that I like are EBC's (i have them) and Raybestos QuiteStop
Re: Re: Brake Pads?
Originally posted by karguy
When doing rear pads you might consider borrowing the Disk Brake Piston Removal Tool to turn rear pistons CW while gently pushing them back in. I bought mine for $6 at Advance Auto.
Turning the rear piston while pushing back in is a real PITA w/o some sort of tool. I did mine with a pair of needle-nose and it was painful.
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
