Headlights out, Help Please
Old Feb 11, 2003 | 06:44 PM
NUGE's Avatar
I just realized that both of my headlights are out. Both bulbs are good. The fog lights & cornering lights work. The high beam works. I can hear the relay clicking. The 15 amp fuses, for the left & right headlights, located in the engine compartment near the battery are good. All other lights are working. HELP ME! Am I missing something? I even set off the stock alarm & the headlights flash like they are supposed to.
Old Feb 11, 2003 | 07:08 PM
(_8*(l)Homer's Avatar
Maybe something wrong with the **** to turn the headlights on. I had to replace mine in my Sentra. Exact same problem as you have. Go to a junk yard, all 4th gen stalks are the same, with the exception of fogs. Other Nissan ones may work too. The 99 Sentra and 97 Maxima are the same.
My 2¢
(_8*(l)
Old Feb 11, 2003 | 07:12 PM
NUGE's Avatar
I don't think that is the problem. I can hear the relay clicking when I go from cornering lights position to the headlight position.
Old Feb 11, 2003 | 09:08 PM
NUGE's Avatar
I am looking at the Haynes manual on page 12-29. Can anybody tell me where the "LIGHTING SWITCH" is located.
Old Feb 11, 2003 | 09:31 PM
JPMax's Avatar
What's next!?..
Did you pull the sockets off the bulb and see if one of the plug in holes is burnt out?
What type bulbs are you using?
Old Feb 12, 2003 | 09:23 AM
NUGE's Avatar
This is bull@#*! Both bulbs are burned out. I don't get it. I thought that if the low beam is out, then the high bean indicator, located in the instrument cluster, is supposed to stay on to let you know that th elow beam is out. I just tried an old stock bulb and it works. I also checked the voltage to the sockets and it is also fine. I guess both bulbs went out at the same time. F%$k this, I don't want to risk frying up my stock harness. I am going back to stock bulbs.
Old Feb 12, 2003 | 11:09 AM
JPMax's Avatar
What's next!?..
Get Sylvania Xtravision bulbs.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
