96GLE won't eject cd after the battery died...
Old Feb 14, 2003 | 11:07 AM
fierostetz's Avatar
my battery ran all the way down (left lights on) and after getting a jump and running again. it won't recognize the cd that is in the stereo, and it won't eject it.. what do i do? it was working fine before? i tried searching, but cd is too short to search for, and i get poor results with everything i tried. BTW its a GLE so the stereo is BOSE. thanks so much!
Old Feb 14, 2003 | 11:30 AM
2maximas's Avatar
Should be some kind of master reset on the head unit, or an emergency eject (like on your cd drive in your computer.... a little hole that you put a pin in that will manually eject the cd)
Good Luck
2maximas
Old Feb 14, 2003 | 12:11 PM
ZuMBLe's Avatar
Re: 96GLE won't eject cd after the battery died...
You try hitting the CD button to kinda tell it you have a CD in there?
Old Feb 14, 2003 | 12:35 PM
fierostetz's Avatar
yeah- this is bummin me out man, just had my tranny rebuilt (2600 bucks!!!) and nowthis... any input is great!! i love how it has a ton of views, but only like 2 responses... SOMEONE has to know what to do.. i looked at it but couldn't find an eject switch on it (like computer) so i don't really know what to do -shawn
Old Feb 14, 2003 | 12:41 PM
phenryiv1's Avatar
Mod her. Ate her.
will it play the CD?
Old Feb 14, 2003 | 12:48 PM
fierostetz's Avatar
no, it doesnt recognize anything in there, but if i open the flap i can see the edge of a cd, it won't eject, won't do anything
Old Feb 14, 2003 | 01:23 PM
phenryiv1's Avatar
Mod her. Ate her.
Try to insert another CD in there. It may be 1/2 in and 1/2 out and the deck may be all confused.
Old Feb 14, 2003 | 01:27 PM
hydroMaxNinja's Avatar
what cd is it?!?!
2maximas's Avatar
Dude,
There has got to be a master reset on the unit somewhere, I gaurentee it. If you can't find it I would try disconnecting the battery again for a while, then reconnect. maybe now that it has had good power on it for a while pulling the power off and then back on may reset it. I wish I could help more, but every CD Player I have ever seen had some type of reset. Have you looked at your owners manual????? There may be a reset procedure in the manual. What year is yours again? I can look at my daughters manual (96SE with bose)
Good Luck
2maximas
Old Feb 14, 2003 | 02:33 PM
fierostetz's Avatar
96 GLE bose... i don't have the manuals, im the second owner. never had any problems with it. i disconnected the battery for a while, then reconnected it. its wierd if i push the cd button, it flickers "cd" on the lcd, then shuts off. the light that says "disc" is lit... i tried pushng another disc in there, yielded nothing.. i am gonna see if i can figure out how to take out the stereo
Old Feb 14, 2003 | 06:22 PM
2maximas's Avatar
I have a website that has the procedure for removing factory stereos in 4th gens go to http://www.maximas.net/html/audio_stuff.html it'll show you how....in the mean time I'll look at my daughters manuals and see if there is a reset procedure in there...
Good Luck
2Maximas
Old Feb 14, 2003 | 06:28 PM
cscm094's Avatar
I would try taking the deck out of the car. Don't try to eject it with it unmounted from the dash though. It won't work. Nissan used the top two screws of the chassis as grounds. Try unplugging the unit overnight. In the morning, plug it back in. Maybe that will reset it. If not, you could always try taking it apart and manually taking the cd out
Old Feb 14, 2003 | 06:36 PM
ZuMBLe's Avatar
I second this one. Each time I disconnect the battery and put it back in. I hear the headunit mess with the CD inside.
Originally posted by 2maximas
Dude,
Good Luck
2maximas
Old Feb 14, 2003 | 08:10 PM
2maximas's Avatar
I looked EVERYWHERE I can think of, I can't find a thing. I did send an email to a shop that specializes in Bose head units and asked if there is a reset....they probably won't answer till monday tho.....Let me know how it goes, and if you get it fixed...just curious now!
2maximas
Old Feb 14, 2003 | 08:35 PM
fierostetz's Avatar
wow, thanks for the responses! still working on this. disconnected the battery, but i don't think i did it for long enough, as the radio settings stayed (left disconnected for almost 2 minutes..) will disconnect overnight, that will HAVE to discharge it i think!
Old Feb 15, 2003 | 03:19 AM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
i realize this probaly doesen't help, but i disconnected my battery yesterday when i changed the fuel filter, and the head unit automatically ejected the tape and CD that were still in there.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
Sep 27, 2015 08:37 AM
