Does anyone have this problem?
Old Feb 16, 2003 | 09:19 PM
Keepdiscoevil
I got a 97 max and sometimes it takes awhile to strart up, and sometimes it satrts up right away. Also my engine idles at like 500. Is that low??
Old Feb 16, 2003 | 10:12 PM
maximabest's Avatar
Re: Does anyone have this problem?
check your starter, and the normal idle is 750 rpms at normal conditions. in cold start is 1200rpms
Old Feb 16, 2003 | 11:11 PM
(_8*(l)Homer's Avatar
Hold your key in the ACC position until the startup ding has ended. 5 times I think it is. THEN start your engine. You will notice it will start up better like that every time your do it. By doing this, you are giving the fuel pump time to pressurize the line.
Your idle should be around 700-800 warm. Clean your throtle body there are buildups of gunk in there. Go to www.maximadriver.com in the How To section.
Easy weekend mechanic task. Takes about 15 min.
My 2¢.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
