99 SE water leak
99 SE water leak
This is my first access into this, so I am going to put this out there and see if anyone has a answer. I purchased a 99 SE a few weeks ago, love the car, but I have discovered a water leak into the trunk. I live in So. Cal. so we don't get much rain. Last week it rained for a few days and i had a couple of inches of water in the spare tire well. Anyone have anything similar?
Mark
Mark
Re: 99 SE water leak
Mark
Mark
I had water in my spare tire well for long time until I found that the rubber gasket around one of my taillights was torn. Replacing it solved my problem.
Good luck!
TOM
Mark
Mark
You might try dusting some baking soda in areas you suspect might be leaking. Then you can see the track in the baking soda that the water made which will lead you to the leak.
Good luck.
Find someone you trust, grab a flashlight, and climb into the trunk. Have your 'helper'(you know, that person you trust to eventually let you back out!) hose down different parts of the rear as you check for leaks from the inside. Worked for me!
litch
123
01-04-2024 07:01 PM
