Lights in the ACC
Old Feb 18, 2003 | 01:58 PM
MacGyver265's Avatar
Lights in the ACC
I just returned from Radio Shack after looking through their lamp bulbs. I found a bulb similar that could work for the Auto Climate Control, but not exactly the same, that could possibly work as a replacement bulb. This would require taking the burnt out bulb out its harness and replacing it with this one. The bulb itself is smaller than the stock ones, so putting those little blue rubber condoms on may be difficult, but nothing a little glue can't handle.
The part number and specs of this particular bulb:
Radio Shack P/N : 272-1092
Bulb number : #7219 (this is the same number standard as stock automotive bulbs, ie: 192 or 1157)
Voltage : 12V
Amperage: 60mA
I don't know if this bulb will work, but I figured I'd put the info out there considering these bulbs were $1.49 for a pack of two and the bulbs from Nissan are like $7 a piece.
Also, does anyone have part numbers for the blue diodes that will fit in the stock ACC bulb harness? How about known resistor values?
I've searched on this before and have found useful sites, but no solid part numbers I could use.
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
