Strut bar Pics
Old Feb 19, 2003 | 12:15 PM
emCee-ig's Avatar
Strut bar Pics
Ok, i finally got enough time to install my strut bar...
the pics are here
http://home.usit.net/~johntom/images/strut/
I need some help, i ripped off the metal bracket as was told to by forum members (my car is gen 4.5) and the brackets went on just fine, my question is:
Tightening the bolts on both the bar itself and the strut bracket to strut,
i am a pc technician, so bare with me.. how do i know how many lbs of torque i use to tighten it? all i have is a tiny ratchet set i got in my stocking one xmas... and about the bolt, how tight do i tighten that as well?
and the lbs... ive seen people saying tighten it anywhere from 30 - 40 lbs, which?
thanks hope the pics help
Old Feb 19, 2003 | 12:21 PM
Bernie Lomax's Avatar
You need a torque wrench.
Old Feb 19, 2003 | 12:23 PM
emCee-ig's Avatar
is that something that controls the flux capacitor?
you see my problem, im a NOOBIE...
i have a ratchet set, and vice grips, thats it,
will these suffice? if so,
Old Feb 19, 2003 | 12:29 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
i'm assuming that you're using a torque wrench. If not, go out and buy one right now. Not only is it necessary when doing a lot of work on your car, it's a great moneymaker when your friends need to borrow it.
As much as i've read, between 30-40lbs is a good range. according to the haynes manual(10-2) it's between 29-40 ft/lbs.
i think that answered the "and the lbs" question....
i'm not sure what else you're asking.... how tight should the bolts on the bar be? Or how tight the upper mounting nuts should be?
PS: A haynes manual is a good investment too.....it'll pay for itself many times.
Old Feb 19, 2003 | 01:08 PM
njmaxseltd's Avatar
The strut bar needs no preload. Just make it the correct size to fit perfectly over the strut tower bolts and snug up the adjusting bolts on the bar itself. Make sure your car is on level ground when you do this.
The 3 strut tower nuts should be torqued to 30 - 40 Ft/Lbs.
In other words, make them nice and SNUG, not super tight and you should be OK.
Old Feb 19, 2003 | 01:18 PM
gtr_rider's Avatar
192.168.1.1
I tightened mine to 30ft lb's, hand measured
Old Feb 19, 2003 | 01:19 PM
Socrates's Avatar
Although I'd like to be a believer that FSTB doesn't look like it's stabalizing SH**
Old Feb 19, 2003 | 02:23 PM
emCee-ig's Avatar
ok
thanks alot guys, i got it on, i went with the "hand measure" as stated by GTR,, i have a torque wrench, i just need to get an adaptor, i will set it the proper weight tomorrow after work
i drove around the parking lot and noticed a difference
thanks again for you help
now, to get my coil packs replaced i'll be perfect =P
Old Feb 19, 2003 | 02:32 PM
Weasel's Avatar
When do you think happens when the strut towers want to defect inwards during hard cornering?
Old Feb 19, 2003 | 02:42 PM
Socrates's Avatar
I would like to know actually
Old Feb 19, 2003 | 02:55 PM
Weasel's Avatar
http://www.maximadriver.com/mods2.html
Old Feb 19, 2003 | 03:04 PM
gtr_rider's Avatar
192.168.1.1
Old Feb 19, 2003 | 03:59 PM
Romeo's Avatar
my FSTB doesn't really do much. all well, only $25
maxima-junky
Oct 7, 2015 06:13 PM
JonBlz
Oct 5, 2015 06:02 PM
followthadollar
Sep 27, 2015 01:06 PM
