95-96 reverse red/clears
Old Feb 19, 2003 | 08:16 PM
Street Reeper's Avatar
Handsome
As we all know red clears are hard to come by, and making them yourself on the 95-96 is about impossible, the only option is covering about everything in red.
So that gave me an idea, if the amber part is stuck what about the lower red lenses. If it was possible to remove the lower half of the stock tailights (which is red) you could clear those out. Then cover the top in red like some have done. Then you would have the same red clear layout that 97-99's have. You would have to do a little rewiring but it could be worth it if it were possible.
I searched 95-96 red clear, and a billion threads came up in case this has been discussed before.
Does anyone have this set up on a 95-96 max, I was wondering what red on top and clear on bottom would look like on the 95-96, they probably would have started out clear, then painted the top of the tailights red, and rewired it.
Old Feb 19, 2003 | 08:30 PM
pocketrocket's Avatar
If you were planning on attempting this procedure on the inner tails as well, which makes it 4 pieces instead of 2, then it'll probably work.
And you will have to rewire the connector so that your turns would be below, the brakes on the top, the reverse on the inners would have to be flipped as well.
Brake lights are 1157 (dual filament), so I guess you will need to flip the connectors as well.
Click on my sig link to see how I did mine.
Or you could change your trunk lid and outer tails with a 97+ and clear it out.
Old Feb 19, 2003 | 09:07 PM
nadir_s's Avatar
vicodin ... gift of life
i don't get it, the pic you linked shows that u have 95/96 red/clears... unless i'm missing something? It's not the 97+ clears!
Old Feb 19, 2003 | 09:19 PM
cscm094's Avatar
He means take the red out of the bottom of our tails, making them clear. Then putting red transparent film over the yellow signals and reverse lights, thus making them the brake lights. Switch the light bulbs and connections around and thats a dam good idea. I thought of this earlier. The brake lights would be kinda thin and the signals and reverse lights would be ultra wide (err tall)....
Maybe I'll take a look at my lights tomorrow. But the question is... Does the red come out of our lights?
Old Feb 19, 2003 | 09:23 PM
nadir_s's Avatar
Oh I understand that part, but pocketrocket's sig link showed something else than what he was talking about.... i think
I never thought about this.... i thought the outside plastic was red itself... is it really clear w/ only a red insert?! this would be the greatest idea ever...
Old Feb 19, 2003 | 09:32 PM
cscm094's Avatar
Ohhh I see what your talking about... hmmm
Old Feb 20, 2003 | 04:48 PM
Hehehe ... the one mod that is better than a sticker
And envied by most in the 95-96 community.
Old Feb 20, 2003 | 05:00 PM
mzmtg's Avatar
Minister of Silly Walks
You cannot remove the lower red half.
It's molded into a single piece with the amber upper half.
We've been over this many many times.
James92SE
142
Jan 2, 2024 09:23 AM
dcam0326
Sep 18, 2015 04:52 PM
Lilfatz301
Sep 18, 2015 08:06 AM
lrb6805
Sep 17, 2015 04:49 PM
