Is there a way to make the gauge lights brighter
Old Feb 19, 2003 | 09:26 PM
mohfo's Avatar
Is there a way to make the gauge lights brighter? My lights seem to be getting dimer.
Old Feb 19, 2003 | 09:36 PM
Chunger's Avatar
My other car is a Hybrid
If the dashlights are getting dimmer (even with the switch set to full bright), you may have a weak battery... If not you could
buy 3 packs of PIAA SuperPlasma H-92 (That's 6 but only need 5). At about $15+ a pair... but they are much brighter (5watt) than the stock ones. The color is WHITE not blue (like the bulb itself).
Old Feb 20, 2003 | 03:52 PM
mohfo's Avatar
Will it burn something out?
Old Feb 20, 2003 | 04:18 PM
Jshock1's Avatar
When I put my indiglows, I noticed that the bulbs inside had a blue plastic cover on them. Do all come like that?
Old Feb 20, 2003 | 04:43 PM
MIXXMAX's Avatar
Yes, they are sometimes called "bulb condoms". They actually make the bulb much "whiter" and spread the light output more evenly.
Old Feb 20, 2003 | 05:22 PM
tzmanles's Avatar
did you try turning that little **** on the right hand side of the steering wheel? maybe its turned down......
Old Feb 20, 2003 | 06:11 PM
Chunger's Avatar
Re: Will it burn something out?
I haven't had any problems for 2+ years
Old Feb 20, 2003 | 08:29 PM
mohfo's Avatar
Re: Re: Will it burn something out?
Yes I turned the dial all the way, Where did you get the bulbs?
Old Feb 20, 2003 | 11:13 PM
JPMax's Avatar
What's next!?..
www.superbrightleds.com
Old Feb 21, 2003 | 12:08 AM
Chunger's Avatar
I'm in Cali so i bought them at a shop in J-town...
I don't like LEDs too much... too narrow a beam to illuminate the sides.
Old Feb 21, 2003 | 02:11 AM
Bgohan's Avatar
If all your dash lights are dim, but other interior lights are OK, you likely have a bad dimmer switch, bad ground in dash, a loose, or a corroded connection somewhere in the circuit. If you have ever messed with dash, you may have loosened a connection.
New bulbs probably will not work, unless putting them in fixes bad connection.
Try the old "take it apart and put it back together" trick. Maybe that will fix it.
-BR, GBHST Graduate. ("Get-Bigger-Hammer, School of Technology")
Old Feb 22, 2003 | 02:58 PM
mohfo's Avatar
where?
tried looking for them in the sight but couldn't find them
Old Feb 23, 2003 | 10:28 PM
JPMax's Avatar
What's next!?..
Re: where?
http://www.superbrightleds.com/1157.htm
Scroll down to Single/4 LED Wedge Base Bulbs. They replace 194 bulbs. The kind in your gauge cluster.
Old Feb 24, 2003 | 01:06 PM
Tino98max's Avatar
what about for a 98 maxima auto SE,,,thanks
tino
Old Feb 24, 2003 | 01:11 PM
JPMax's Avatar
What's next!?..
tino
98 & 99 models are more difficult. They don't use the normal 194 bulbs, no one really knows what size it is, only the dealer carries them, and they only come in clear.
(At least to my knowledge..)
Old Feb 24, 2003 | 01:21 PM
Tino98max's Avatar
damn it, has to be somewhere out there with them, i heard the same info too, who knows, i guess it sux for now, until one does come out
thanks tino
Old Feb 25, 2003 | 08:35 AM
cam_honestiam's Avatar
Instrument Panel Bulbs
I just had a bulb go out on my '98 SE and I replaced it with a Sylvania #74 that you get at Auto Zone or Checker (you should tighten the metal contacts in the socket with a jewler's screwdriver for a perfect fit), or even Wal-Mart. Save time and money and put it in yourself. Also, if you want the "bulb condom" as was suggested, you can find an assortment of "vaccuum caps" that are small enough to slide on as a sleeve, coming in several colors, at Auto Zone for $3.99 - These should resist the heat put out by th bulb and come in yellow, red, blue, and white. You may need to modify some for size, but they are a cheap alternative to colored bulbs.
Old Feb 25, 2003 | 08:39 AM
Dual Reply
thanks tino
<<SEE REPLY>>
Also, if you want the "bulb condom" as was suggested, you can find an assortment of "vaccuum caps" that are small enough to slide on as a sleeve, coming in several colors, at Auto Zone for $3.99 - These should resist the heat put out by th bulb, and come in yellow, red, blue, and white. You may need to modify some for size, but they are a cheap alternative to colored bulbs.
Lilchikcadee
May 1, 2019 08:49 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
homeyclaus
Sep 3, 2015 06:15 PM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
