gas pedal sticking only durring take off
Old Feb 20, 2003 | 07:50 AM
acmesafety's Avatar
my gas pedal sticks a little when i start to take off from a stop. as long as i have pressure on the pedal it does not stick it only sticks when i let completly off and then push again. any help would be great
thanks
Old Feb 20, 2003 | 08:02 AM
njmaxseltd's Avatar
Check that the linkage at the throttle body isn't hanging up on anything. Spray some WD-40 on it as well. If you still feel it hanging up, it's time to change the throttle cable.
Old Feb 20, 2003 | 08:11 AM
slizan99's Avatar
Re: gas pedal sticking only durring take off
thanks
if you have an aftermarket intake, some people have been having problems with the linkage getting caught..something to think about.
i would lube it with silicone lubricant
Old Feb 20, 2003 | 08:39 AM
burrll_gee's Avatar
could also be huge gunk buildup in throttle body... when mine was sticky last summer, i cleaned throttlebody and butterfly valve... it was like a 1/8 inch thick ring of gunk all around the valve, so whenever i let completely off the throttle the valve spring would push the valve into that gunk... making me have to push a little harder to "unstick" it.
So clean your throttlebody like this Throttle Body Cleaning
Should fix you right up.
BG
Old Feb 20, 2003 | 11:13 AM
michael7278's Avatar
I Agree - Same here
BG
Same here, had the same problem, cleaned the throttle body and Butterfly valve, fixed it. after cleaning, I sprayed some WD40 in to the hinges of the butterfly valve.
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
