Should I be worried?
Old Feb 20, 2003 | 11:20 PM
Mr.95GXE's Avatar
I was on the highway coming home when I see a VW Jetta(older model) screwing around with other traffic. I speed up to see what he will do. Right when I get next to him he guns it. While I'm fishing for 3rd gear(stock shifter isn't all that great) I decide to just grab 4th when I really had it in second at around 80mph. I let the clutch out for a second and hear the car scream to about 7,200-7,500rpm. Car runs and sounds fine. Should I be worried? It was only for about a split second, I heard the car rev violently, saw the tach, and stepped on the clutch again. Quick run down of what my car is.
'95 Maxima GXE 5spd. w/178k miles.
Mods: none, this car is factory stock, not even a replacement K&N.
Old Feb 20, 2003 | 11:25 PM
DerekJ212's Avatar
Re: Should I be worried?
The car has a rev limiter to prevent damage. Assuming you got off it reasonably quickly and dont do it again, youll be fine.
Derek
Miasma's Avatar
look for leaks from high oil pressure, but if it works ok, then just learn and move on. no check engine light? the main prob that can occur is head crashes, when the pistons are moving faster than the valve lifters release. that is very bad, and you would know if that happened.
Old Feb 20, 2003 | 11:34 PM
Mr.95GXE's Avatar
Car seems fine, no check engine light, no new noises from the engine. I didn't even get into the throttle when this happened. I let the clutch out to see what rpm I was going to be at and noticed. lol, and I just replaced the water pump today.
Old Feb 20, 2003 | 11:37 PM
Miasma's Avatar
Re: Re: Should I be worried?
Derek
rev limiter does nothing if you drop the car in gear at a higher speed than the engine can handle. all it means is that you will not get any fuel when you have a head crash .
02PearlSE
Feb 1, 2016 12:37 AM
carid
Sep 17, 2015 05:00 AM
Jay556
Sep 12, 2015 05:50 PM
stromm
Aug 27, 2015 04:13 PM
Jcof88
Aug 3, 2015 10:43 PM
