Just a piece of advice !
Old Feb 21, 2003 | 01:39 PM
humberto_i30's Avatar
Finally the annoying sound of my Infiniti I30 when hitting potholes and uneven roads are gone, just as advice, don't use KYB Strut Mounts in your Maxima/I30 for any reason, replace them with OEM mounts, and don't forget to replace the strut bearing when replacing strut mounts or struts regardless of condition, they make a whole different handle on our cars, and help avoid weird noises in the front suspension.
Old Feb 21, 2003 | 03:10 PM
njmaxseltd's Avatar
I've always said to use as much OEM suspension components as possible.
Your not the first one to complain about KYB mounts.
Old Feb 21, 2003 | 03:34 PM
Buying KYB strut mounts are waste of money, $75.00 for a pair and they finally are useless ! Damn ! As njmaxseltd always said, USE as much OEM Suspension Components as you can, you'll be not dissapointed.
Old Feb 21, 2003 | 03:59 PM
njmaxseltd's Avatar
Originally posted by humberto_i30
$75.00 for a pair
The OEM mounts are cheaper too.
Old Feb 21, 2003 | 04:36 PM
Max4Speed's Avatar
www.autotalk.com
I have those noises too but still on stock stuff. I have replaced the bearings but didnt replace the strut mounts. What exactly I need to buy and replace? Please list the parts :-D
Old Feb 21, 2003 | 04:57 PM
If you already replaced the bearings, just replace the strut mounts and that's all !
Old Feb 21, 2003 | 06:19 PM
SLC I30t's Avatar
what does the strut mount look like? I have KYB's and it I hear bizarre noises from my suspension. Sounds like a vibration. I did the coil wrap but it didn't work for me.
Old Feb 21, 2003 | 08:04 PM
Don't waste time asking how the KYB mounts look like, just replace them with OEM strut mounts, you'll feel the difference right away, another whole world riding on new strut mounts if your struts are still good, of course, otherwise replace your struts also.
Old Feb 21, 2003 | 08:16 PM
SLC I30t's Avatar
well since I don't know if I used KYB mounts or OEM mounts... how about humoring me with a description or a picture.
Old Feb 22, 2003 | 09:28 AM
Sorry
Will be difficult to take the picture, you need to disassambly the whole front suspension (Strut, Spring, Mounts, etc) to get a picture from the strut mount, so I can't help you here !
Old Feb 22, 2003 | 11:38 AM
SLC I30t's Avatar
well then what did it look like? The only thing I got with my KYB's was that strut itself and a new nut for the top of the strut to hold it to the assembly.
Old Feb 22, 2003 | 05:01 PM
I have looked the OEM mounts and the KYB mounts and are very similar almost identical, but the OEM are softer than KYB and they look higher quality also. Don't worry about the looks or shape of your KYB strut mounts just replace them with OEM ones and you'll be not dissapointed for sure. The mechanic at the stealership told me that the KYB strut mounts look like they are just worn but painted, so don't trust KYB strut mounts any more, I'll not do it for sure.
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
