Starting stalls & Belts squeek bad now?
Old Feb 21, 2003 | 03:35 PM
bobjohnson's Avatar
Blazin......
Ive Had this Starting Problem in the Morning For 2 months still.
Its starts, and it stalls again. it does this until i put my foot into the gas. THEN: it finally starts and stalls if My foot is not on the gas for a minute.
Now the belts squeek horribly because its not in warmed up and the engine is idleing @700rpms to warm up.
Ive replaced KS, fuel filter, ECTS, sparkplugs.
What else can i do, im considering selling and starting over. Help!
Old Feb 21, 2003 | 03:58 PM
njmaxseltd's Avatar
Clean your throttle body.
Check the cold fast idle cam and plunger assembly.
Check your Engine Coolant Temperature sensor to make sure it's giving the correct values at cold temperatures.
Those are the 3 key things that make our cars start and idle correctly when it's cold.
A Haynes manual is your friend.
Old Feb 21, 2003 | 04:22 PM
bobjohnson's Avatar
Blazin......
Thankyou so much , your knowledge is appreciated. i can tell after doing a search with the "fast idle" you've seen this before.
THankyou again.
Old Feb 21, 2003 | 04:26 PM
njmaxseltd's Avatar
Let us know how you make out.
Old Feb 21, 2003 | 05:26 PM
bobjohnson's Avatar
Blazin......
FOR SURE!
For sure, i will . ive had this problem for so long and needed some extra routes to take.
tsi6001
Oct 3, 2022 10:23 PM
mvm062
Nov 30, 2020 09:00 AM
Lowered_a33
Sep 1, 2015 07:49 PM
FlaMark
25
Aug 28, 2015 10:15 AM
JMag90
Aug 25, 2015 09:17 AM
