Skyline Gauges?
Looks like it might need modification to fit, as it doesn't look exactly the same as our Max guage shape.
Not sure about the electronic part, but if you can get the wiring to work (like you said, the connectors are different), then it might be possible - if you get it working nicely, props for being unique!
those gauges are gorgeous!
is it an issue that the speedo goes up to 180? it interperts the same data right, so it should still work (just to a higher speed)?
please keep us updated, though it looks like a tough install, i bet it can be done. also, the plugs on the back are not necessarily different, wouldnt that be convenient?
Those gauges look tight! It could prolly fit with some modification. There are a few problems tho: It looks like there is an oil temp under the tach, it wouldnt work unless you found a way to manually hook it up. The redline on the tach is at 7k instead of 6500, not that big of a deal as long as u remember. You would have to get an older one, the newer ones have the digital odometer, and it looks like you have the analog. Id try to find the dimemsions because getting it to fit will be the hardest part. The plugs look to be the exact same which is great.
How about some skyline R33 mirrors to go with those gauges?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6745
Re: Re: Skyline Gauges?
Originally posted by d_warner
And here's the backs. Obviously, the wiring connectors would be a PITA.
Backs:
4th Gen
Skyline
Just a thought. No flaming please.
Backs:
4th Gen
Skyline
it might work..
how much it the skyline cluster?
Originally posted by fearthegecko
stupid question.....will the odometer read it as miles or KM? since if you take it off a wrecked skyline, you figure it's been reporting kms, if you put it in a max, will it report miles?
http://www.e-insite.net/tmworld/inde...edometer Work?
Hahah
Dude you should do this, but before you do it, make sure your Maxima can go that fast!!! Not to burn you but dude that would be so awesome, People say that the Maxima is really a 4dr Skyline in disguise, except a little downgraded and more family like.
Originally posted by Skyline
Straight off the bat it will be an incorrect reading, you will have to calibrate it. The face, you could even draw your own for 300mph and then modify the speedo for it.
Thanks guys. We'll see what happens with my 5th gen as far as repairs go, and Now I got to pay a ticket that my wife got last night. This is turning out to be a bad month. BTW The gauges are on ebay. Current bid is 71 bucks. Link to Ebay Yes, I realize that they only go to 180 kmph. Like 110 mph. We'll see.
David
David
220k+ A32
18
09-22-2015 11:39 AM
RWCreative
09-21-2015 11:01 AM
