need code translation
Old Feb 22, 2003 | 09:15 AM
devious max's Avatar
what does these code mean p1605, p1105, p1220. i got those same code twice so there are like six code instead of three
Old Feb 22, 2003 | 09:17 AM
iansw's Avatar
Re: need code translation
No, the ECU simply starts replaying the codes in a loop when in diagnostic mode.
But those codes you give (p1605, p1105, p1220) don't make any sense - what does the "p" mean? and the firt 2 numbers can never be over 13...
This is the ECU you're talking about, right?
Count Long Pulses first - whatever that number is is your first 2 digits - 01-13
Then short - this is the last 2 digits...01-15
I shouldn't need to explain - there's a Forum Sticky that explains it all....
http://vbxmaxima.8m.com/ecudecoder.html
Old Feb 22, 2003 | 09:42 AM
these are the code given to me by the autozone tech when he checked my car
Old Feb 22, 2003 | 09:47 AM
iansw's Avatar
He's using an ODBII Scanner - these aren't the same as the ECU Codes, although they diagnose the same thing. if you want to figure out what the codes mean, you need to pull them yourself.
Read the sticky on top of this forum for how to get the codes and diagnose them.
Click Here
IanS
Old Feb 22, 2003 | 09:56 AM
one of the code mean map baro solonoid dont know what that mean any suggestion?
Old Feb 22, 2003 | 09:58 AM
another code say signal from ecu to transmission ecu
Old Feb 22, 2003 | 10:16 AM
Jason R's Avatar
aka UNCDooD
it'd be much easier for people to help if you pulled the codes yourself instead of going to AutoZone.
Old Feb 22, 2003 | 02:51 PM
Zirafa's Avatar
Haynes says:
OBD-II Trouble codes:
p1605=A/T control unit or circuit fault
p1105=Manifold absolute pressure solenoid valve or circuit fault
p1220=Fuel pump control module or circuit fault
Old Feb 22, 2003 | 05:08 PM
how can i fixed these item
Old Feb 24, 2003 | 05:04 AM
Zirafa's Avatar
I really wouldn't know how to fix these but perhaps they are something you could do yourself instead of going to a mechanic. Pick up a Haynes manual at a parts store (about $15) and start from there. Also, this online version of Chiltons may help you; check it out
http://www.cybrrpartspro.com/Manual%...delLookup.html
Good luck!
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
