exactly what size are gauge cluser bulbs....
Old Feb 23, 2003 | 05:20 AM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
I'm talking about OEM gauge cluster bulbs. I went to my local nissan dealer last week, and the guy says he has 3 different choices for them (naturally none of which are in stock). I want to replace my oil light and my gas light, and the only way i can get a definite match would be to take out gauges, remove bulbs, put back gauges and bring the bulbs to the dealer to match up, go home, take apart the dash again, and replace bulbs. So, does anyone know the part numbers for these bulbs on a 99 Se-L? I'd try courtesy, but they do not giveout part numbers......
Old Feb 23, 2003 | 08:42 AM
D1NOnly34's Avatar
Re: exactly what size are gauge cluser bulbs....
All i know is that the 5 bulbs for the speedometer and gas, etc.. are 194 bulbs.
Old Feb 23, 2003 | 09:38 AM
clee130's Avatar
Re: Re: exactly what size are gauge cluser bulbs....
Not for a 1999 Maxima they aren't.
And taking apart the dash is pretty easy albeit time-counsuming.
Old Feb 23, 2003 | 10:17 AM
95emeraldgxe's Avatar
for the 99's the bulbs are like 1/2 the size of 194's, you can probably manage to splice some LED's from radio shack onto the spots
Old Feb 23, 2003 | 11:33 AM
you're right, i could splice, and i could put brighter aftermarket bulbs in, etc, etc. But i don't want to. I want the OEM ones with the little stupid plastic thing already on the end, so all i have to do is screw them into the socket.
Old Feb 23, 2003 | 11:02 PM
JPMax's Avatar
What's next!?..
Well, if the dealer had them in stock, I'd suggest just going to the dealer, parking there, take the cluster apart and pull the bulbs you need replaced.
Taking the dash apart is a 5 minute job once you get used to it and have the right tools.
Only thing I can suggest is try calling several dealers and see if one has them in stock.
My parts list doesn't list a part number either..
You could try picking up a pair of 74 bulbs at Autozone ($2-3). They're smaller than the stock bulbs and not as bright, but they'll work as a temporary replacement.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
kadespraggins
Sep 14, 2015 12:04 AM
