help my pass. side blinker wont work
Help guys I have tryed 4 diffrent bulbs and I checked the wire today with a test light and no jucie is there.is there a fuseable link or fuse some where i should check?
If the other side blinker works, then its not your fuse.
You should go to the blinker stalk and test for current going to that blinker. The best thing you should do is get a wiring diagram for the blinkers and you will be able to figure where to test the circuit
yeah that what i was thinking
what else could it be ?when you turn on the right blinker it blinks fast like the bulb is out. strange, I cant fig this out...ok were can i find a skimatic?
try this but i donno...
change to higher voltage (such as 15A or 20A) maybe it'll work... i did this setup to my tail, it was originally 7.5A and it kept blowing my bulbs and my fuses... i changed it to 20A and now it's workin fine...
give it a shot =)
give it a shot =)
Re: yeah that what i was thinking
Re: Re: yeah that what i was thinking
Originally posted by CystumMax
IT blink fast because the bulb is out, its giving you a warning so you know why its blinking fast. Are you using after market bulbs?
Re: Re: Re: yeah that what i was thinking
I have tryed apc,reg autzone bulbs,polorg,and even tryed putting the bulb that was in there when i got the car nothing works,this is killing me cause it was working before i put the clears in.
Re: help my pass. side blinker wont work
Re: Re: Re: help my pass. side blinker wont work
lol that worked thanks man!!!!!!!!!!!
Re: Re: Re: Re: help my pass. side blinker wont work
Originally posted by Cumalittle
did it really??? cuz i had that happen to meeh once...was driving meeh nutz...wat happen was the contact on the socket was sitting flat when it should have been sticking out a lil bit to make contact w/ the nipple on the bulb...look at ur socket...and take something small and non-conductive and pull the tab out some...
jerrod99_se-l
Aug 27, 2015 08:27 PM
shaunkey1
Aug 18, 2015 10:09 PM
jchronis2552
Aug 13, 2015 07:48 AM
