Help!!!! Max Broken!!!!
Old Mar 3, 2003 | 08:01 AM
MaximaMoJo's Avatar
I posted this thread in the General Forum and it was suggested that I try hear as well.
This is the deal, I go and park my car for a second, then I get right back in and try and start the max. I go and turn the key and when the key gets to the ACC position I lose all power. I mean everything, no lights at all, no dome headlights, no radio, NOTHING. So, I think it is the battery or a fuse. I replaced the battery because it was the original battery.
I then checked:
1 Every fuse and relay (in the car and under the hood)
2 The battery leads
3 The starter solenoid
4 The ignition switch
When checking relays and switches I used a volt meter to test for resistance and continuity. Everything checked out OK. I have no clue what is wrong. Does anyone have any guesses? Oh by the way it was raining and my car was sitting in water when this happened. I am pretty sure it is a short.
Old Mar 3, 2003 | 08:43 AM
AssyrianRacer
HAhh
If you have a 99Max, its your Immobolizer, You have to reprogram your key and comp, costs 120
Old Mar 3, 2003 | 09:02 AM
MaximaMoJo's Avatar
I just called Tom Wood Nissan in Indianapolis and talked with a tech. He stated that if it was the immobilizer system the car would start and die repeatedly. I don't have any power what so ever. For those of you that had the immobilizer problem, did you lose all power (radio, lights, etc.) or were you just unable to start the car?
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Quickywd01
Sep 21, 2016 09:36 PM
maxima297
Sep 30, 2015 03:32 PM
jds22
Sep 29, 2015 02:03 PM
