Clutch started disable relay
Old Mar 3, 2003 | 12:01 PM
tweaked's Avatar
Hello all,
I have a 5sp with no clutch started disable relay. (ie I can start the car without depressing the clutch) So I looked under the hood for the Starter Inhibitor Relay in the relay box #2. There is no relay and no connector in the bottom of the box where the relay should be. How can this be? Could the previous owner have change from auto to 5sp transmission? What am I missing? I would like to install the relay before me (or my wife ) start the car without depressing the clutch and I have to fix the bumper again!
Thanks for any help you can provide,
Stephane
Old Mar 3, 2003 | 02:20 PM
PedalKick's Avatar
I see from your profile you're from Canada. Canadian Maximas, at
least '95s, do not have a clutch starter disable relay.
Old Mar 3, 2003 | 05:18 PM
tweaked's Avatar
Thank you very much for your reply. I guess it wasn't wired for it either? What is the switch that is activated when the clutch pedal is fully depressed used for?
Thanks again
Old Mar 3, 2003 | 05:56 PM
Nismo's Avatar
Thanks again
cruise control?? there are actually 2 switches on the clutch pedal, one on the bottom when its fully pressed and one on the front that activates when its slightly pressed.
BkGreen97
Apr 2, 2016 05:47 AM
97_GXE
Sep 15, 2015 06:47 AM
trungg86
Sep 4, 2015 04:58 AM
A32goldylocks
Sep 2, 2015 06:39 AM
