Are there any disadvantages of a RSB?
Old Sep 12, 2000 | 07:37 AM
MAX99SE's Avatar
Like problems with jacking up the car or anything? I heard about something like that earlier. Please advise.
Old Sep 12, 2000 | 08:15 AM
mingo's Avatar
dunno bout that
well if u use a hoist to jack it up, u won't b able to jacke it up using the suspension components ne more. u can still use the factory jack points tho.. but i heard u get oversteer instead of understeer after the rsb installation.
Old Sep 12, 2000 | 08:20 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: dunno bout that
well u can jack at the suspension..just not at the bar i think.
the fwd have a tendency to understeer in turns...so to offset that...RSB will add oversteer...but not to the point that's dangerous...just a little more balanced feel.
Dan
Old Sep 12, 2000 | 08:24 AM
mingo's Avatar
hmmm
well for nutty drivers.. u can drift with this car without using the e-brake.. if u should always remember when u jack try to have asmuch contact with the car as possible more surface area means less stress on one point
Old Sep 12, 2000 | 08:32 AM
MAX99SE's Avatar
Re: hmmm
Well, what about when I go to the dealer and they use a lift for the car, would the RSB cause any probs with that?
It would not void the warranty or anything, right?
Old Sep 12, 2000 | 08:36 AM
Supa Lao's Avatar
You're gonna have no problems w/ the dealer lifting your car up w/ the RSB. They don't jack the car up by the suspension
Old Sep 12, 2000 | 08:55 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: hmmm
block-O-wood helps a lot on the jacking...i have no problems with my friend's lowered car w/ the RSB.
you can drift a lot of cars w/o e-brake..heehee..just how hard u want to rip up your tires.
Dan
Old Sep 12, 2000 | 10:15 AM
Keven97SE
The only bad handling affect is that the rear end is a little more nervous when cornering on bumpy roads. There's less independence back there with the RSB, so you'd expect that. I had to disconnect my ADDCO RSB (had a broken bracket) for a few weeks and noticed this...still, when I hooked it back up, the handling improvement outweighed the increased nervousness.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Albertt
Aug 30, 2001 12:31 AM
Cumalot
Dec 16, 2000 11:55 AM
