Just Turned 30Kish
Im just about to go over 30, and I did my maintenence
You didn't say whether you have an auto or a 5spd, but I changed my transmission fluid with Redline MT-90 and I really noticed a difference. I also changed my oil and oil filter, checked my fluid levels (it turned out I had no washer fluid), and checked my tire pressure. I recently painted my brake calipers, and I checked my brake pads and they had a ton of life left on them so I'm not worried about them. I kept looking for stuff to do at 30k, but really there isn't much you need to do unless something needs replacing.
Hope that helps.
-hype
You didn't say whether you have an auto or a 5spd, but I changed my transmission fluid with Redline MT-90 and I really noticed a difference. I also changed my oil and oil filter, checked my fluid levels (it turned out I had no washer fluid), and checked my tire pressure. I recently painted my brake calipers, and I checked my brake pads and they had a ton of life left on them so I'm not worried about them. I kept looking for stuff to do at 30k, but really there isn't much you need to do unless something needs replacing.Hope that helps.
-hype
Originally posted by Naughty
MY 98 Maxima just turned 30Kish....what are some of the things that i would need to do.... other then getting an oil change.. Should I change my Plugs? Water? ..kinda lost ....
Plugs and coolant are changed at 60K.
30K??????
thanks
thanks
What, only 30K, dam weekend drivers, just kidding, man I must really drive alot, I expect to hit 90K by the end of this month on my 98 GXE.
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
