Weather and Performance changes
Old Mar 4, 2003 | 09:25 PM
FormorAccordMan's Avatar
Hey all,
Here in Brooklyn, the weather up until a few days ago has been disgusting. Rain and all that good stuff. Since I picked up the car a month ago I was never truly impressed with it's perfomance ( yes i know it is stock, but still...) Anyway, tonight was a clear night and the snow is melting/drying up. Tonight, as I drove, i noticed that the car was pulling better and seemed alot quieter/smoother especially from a red light. Am I imagineing things? Anybody experience this? Why should the weather have anyting to do with it? I am slowly learning about the Max, and this car has been a launch for my auto education. Anybody have a similar experience? Is the max sensitve to weather? I ahve a k and N drop in filter if that makes any differnce. Thanks for your help!
Old Mar 4, 2003 | 09:32 PM
heems27's Avatar
A car will not run at its best when its real cold or real hot. The optimum temp. range is from 55-75 degrees. The ECU compensates for outside temperature.
Old Mar 4, 2003 | 09:52 PM
mayhemI30's Avatar
"I'm running with scissors!"
Re: Weather and Performance changes
Originally posted by FormorAccordMan
Hey all,
if you drive fast a lot the ecu starts to learn your driving habits
an it will slowly adjust things with a/f, shift points,etc. to a certain extent. it would be somewhat noticeable
Old Mar 4, 2003 | 09:55 PM
mayhemI30's Avatar
when i got my i30(repairable) i notice that the harder i drove it got somewhat faster. sounds stupid but true
Old Mar 6, 2003 | 06:34 AM
BEJAY1's Avatar
Conecarver
Colder air can increase performance drastically; and air density. I think the rule of thumb is +1%hp for every 10deg drop in intake temp.
Old Mar 6, 2003 | 09:08 AM
venompwr2's Avatar
yes cold air is more dense and gives you a little more performance when it is cooler outside. Up here in NY, the fall and spring are nice to drive around in. I dont know the hp #'s, but that is true.
Old Mar 6, 2003 | 11:17 AM
StygianMax's Avatar
Humidity is a negative factor too.
Old Mar 6, 2003 | 12:10 PM
Str8ridin's Avatar
Cold air effect on our Maxima:
http://forums.maxima.org/showthread....e+Temp+results
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
TKHanson
Nov 24, 2018 01:39 AM
Socalstillen
Sep 26, 2015 12:01 PM
Dasmith
Sep 23, 2015 08:28 PM
