Could it be my Rear Heated O2 Sensor???
Old Mar 5, 2003 | 04:49 PM
D1NOnly34's Avatar
Well about a month and a half ago my engine was acting real weird, it was knocking like crazy. I changed all my spark plugs, replaced a spark plug coil, new fuel filter, and a new knock sensor. At this point I thought my car was fine. Well about a month ago, I was with my friends in my car, I floored it and I look down to notice my check engine light is on. The next day I pull the code and its my "Rear Heated O2 Sensor". My car felt like it was running fine so I tried to reset my ECU to see if it would come back. The cel never came back on. Now, my car is back to its jerking/knocking stage, only at idle though, when driving you dont feel any hesitation or knocking, only when in Drive and in idle. I never did change my O2 sensor, could this be my problem? Its gradually getting worse and I cant stand it. What should I do. My car has 94k Miles and is a 95 SE. Thanks
Old Mar 5, 2003 | 10:44 PM
PedalKick's Avatar
The rear heated O2 sensor is just to monitor the main catalytic
convertor operation. If it is not functioning correctly,
your exhaust emissions would increase. There is no effect on
your engines performance or anything else.
Old Mar 5, 2003 | 10:48 PM
PedalKick's Avatar
To clarify, emmisions go up if the catalytic convertor is
not operating correctly. The only affect of the O2 sensor
not operating correctly is you get a light on yer dash.
Old Mar 5, 2003 | 11:08 PM
hakk97se's Avatar
I doubt that is causing the jerkyness, but you might want to jack up the car, pull the o2 sensor and spray it with some brake cleaner. They tend to get build-up over time.
Old Mar 6, 2003 | 07:01 AM
D1NOnly34's Avatar
SO then why is my car acting stupid?
Old Mar 8, 2003 | 07:15 PM
philly96maxima's Avatar
only people act stupid, maximas arent stupid,just get sick sometimes.
Old Mar 8, 2003 | 09:13 PM
D1NOnly34's Avatar
Old Mar 13, 2003 | 07:39 PM
Lost_N_a_97Max's Avatar
I'm having a simalir problem with my 97 auto gle, with 70,000 miles.
I got the 0707 code after flooring it in a parking lot. Reset, and hasn't come back on.
I have an intake, budget y-pipe, and magnaflow catback exhaust... my best time is 16.09 @ 85.83
I know i should be doing alot better even with an automatic.
Anyone have this problem and had it fixed yet?
Old Mar 17, 2003 | 08:29 PM
StygianMax's Avatar
How long had it been that you reset your ECU?
I just had 0707 code kick up today. I feel the same about my 1/4 ET (bearing in mind all the differences that could affect things like slickness of track, humidity, etc.)
Old Mar 17, 2003 | 08:57 PM
happyricefob's Avatar
V^___^V
yeap my rear and knock kicked in last week, gettin the O2 replaced cuz my cat is kinda dirty, so i will be gettin random tech before apexi WS catback (kinda weird), but anywayZ it's probably not a big deal if jus spray some brake cleaner unless u wanna change it new for good.
Old Mar 17, 2003 | 09:51 PM
vipervadim's Avatar
I like Maximas
is there a way to test the 02 sensor with a voltmeter?
Old Mar 17, 2003 | 11:41 PM
V^___^V
i know my technician is runnin voltmeter to test the O2's reaction rate... i think it's between .2-.7 voltage., he said my 0304 and 0707 should be fixed in the next 2 days with a detail report... i'll keep u posted =)
Old Mar 18, 2003 | 01:03 AM
I've got an idea on why my best time isn't what I'm looking for... so I'm gonna try something wednesday night when i race and see if it's what I think it is...
Should it be, I'll describe what i do.
Old Mar 18, 2003 | 05:03 AM
StygianMax's Avatar
What's the root problem that causes the rear heated O2 sensor to be tripped? Is it too much O2, too little? How's this related to the performance of the cat (ref. PedalKick's post)? Help!
I reset my ECU last night but it tripped again this morning.
Thx for any additional insights.
Huttig2009
Sep 25, 2015 03:31 PM
iflexsteel
Sep 15, 2015 03:37 AM
homeyclaus
Sep 3, 2015 06:15 PM
Maxilano
Aug 31, 2015 07:33 PM
