0512 and 0510 codes
Old Mar 6, 2003 | 12:01 PM
yamas's Avatar
0512 and 0510 codes
Hello... I found this site last night and there is a ton of information here. I found out how to check the codes on my 99 se and got 0512 then 0510. I did a few searches and found out some information. I was just wondering if anybody knows any correlations between the two. If so, what should I check first? Is this something that can affect performance and cause serious problems to my car? The decoder didn't have either of these codes but there were a few posts on each in the forum, what a great site.
Thanks for any help.......Brian
Old Mar 6, 2003 | 04:39 PM
MIXXMAX's Avatar
Re: 0512 and 0510 codes
Both codes are related to the rear O2 sensor in the catalytic converter. Code 0512 relates to a high voltage fault, and code 0510 refers to a maximum voltage monitor fault. I would just replace the sensor itself and see what happens. Or, you can go to a Nissan dealer and they'll run a diagnostics on it to be sure. (But, be prepared to spend some money on that diagnostics.)
Old Mar 6, 2003 | 06:23 PM
yamas's Avatar
Thanks alot for your help, I'll check it out. I just bought a Haynes manual so I can probably just replace it. Is it that diffucult? Should I do it soon or is it ok do drive on it for a while? ie. wll it hurt the car and affect performance?
Old Mar 6, 2003 | 08:10 PM
fisher's Avatar
Re: Re: 0512 and 0510 codes
Just went though same thing about 2 months ago. Bought rear O2 sensor from Courtesy Nissan. Cost including shipping was $65. Took 2 days to receive. Went to Autozone and used there free rent a tool program for an O2 socket wrench (Must Have). Took 5 min. to replace sensor. Easy to do. Reset ecu, all is well.
Old Mar 6, 2003 | 08:34 PM
SpeedFrk38's Avatar
I got a 0510 and took out my sensor and cleaned it. So far it's been 2 weeks and no Service Engine Soon lights. *knock on wood*
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
