spring install
Old Mar 6, 2003 | 05:09 PM
los-maxin1's Avatar
spring install
If I install sprint springs alone will it harm anything? Do I need to do the whole shocks,etc? Thanks in advance
Old Mar 6, 2003 | 05:24 PM
The Gange's Avatar
Re: spring install
you stock shocks and struts will last about two weeks and they're gone. It is best to combine all lowering springs with some sort of Performance strut such as KYB AGX.
Here is some help.
http://forums.maxima.org/showthread....tions+answered
Gange
mikese's Avatar
I think you do need aftermarket struts becauseof the 2.0 inch drop. You strut will go bad after that if left with oem struts, correct... anyone
Old Mar 6, 2003 | 08:09 PM
los-maxin1's Avatar
Thanks guys. I imagine this applies to any springs I install.
Old Mar 6, 2003 | 08:45 PM
iansw's Avatar
Also, for a dorp that low, you will need at least Eibach Camber bolts.
They're like $30.00 at www.southwestautoworks.com
And an alignment
Also, there is a small chance that your axles will get destroyed by being too low - It's only happened to a couple of us, but be aware.
Old Mar 6, 2003 | 08:46 PM
96shogunmax's Avatar
And an alignment
no camber bolts needed here. but its your call. mine aligned perfectly
Old Mar 6, 2003 | 08:47 PM
iansw's Avatar
Mine were way off - even with the camber bolts, they couldn't get it within spec completely.
I'd do it, just to be on the safe side - $30 isn't much to spend.
Old Mar 7, 2003 | 06:36 AM
los-maxin1's Avatar
Thanks Fellas. I think im going with the maxspeed's after reading that article as I am not looking for such a drastic drop.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
