Taillight Goo
Old Mar 8, 2003 | 09:02 AM
djshawnee's Avatar
Taillight Goo
Hey guys, I am trying to take out the taillights to make red/clears, but I can't get the taillight off. The goo is just too strong.... My hand hurts from trying to push it. I even got in the trunk and tried to push outwards. It didn't budge at all. Any suggestions? I bet this has already been covered, but the search button is disabled.
Old Mar 8, 2003 | 09:04 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Re: Taillight Goo
if you have heat gun, get in the trunk and try to heat it up. not too much heat just go around couple times. then give it push.
Old Mar 8, 2003 | 09:35 AM
MistaPeerez's Avatar
ive heard to use a blow dryer too
Old Mar 8, 2003 | 11:11 AM
pjalst
push like hell
Old Mar 8, 2003 | 11:55 AM
NYCe MaXiMa's Avatar
push harder
if it's cold where you are, it will definately be even more of a ***** to push them out..
just push harder.. and evenly on all corners..
don't ever attempt to pry them from the outside.. you will likely crack something
they are extremely fragile..
Old Mar 8, 2003 | 01:50 PM
spiff56747's Avatar
you took off the 4 nuts from the back of the taillight right? Not to make you sound dumb, but we gotta check all possibilities
Old Mar 8, 2003 | 01:54 PM
djshawnee's Avatar
haha.. i did take the nuts off. It is like 35 degrees here... so the goo was really solid. The heat gun thing worked perfectly. My red clears turned out good..... except i cracked a part of the clear plastic (oops), but I epoxy'd it back... so it looks almost as good as new.
Old Mar 8, 2003 | 02:37 PM
pjalst
Got pics?
Old Mar 8, 2003 | 05:03 PM
StygianMax's Avatar
I had the same oops and epoxied too.
If you have goo to clean off your car, "Goo Gone" works well.
Old Mar 11, 2003 | 11:19 PM
JGrAsS's Avatar
What I did was bang on the bolts w/ a hammer after I unscrew them. It certainly help bulge the taillight....Then push like hell!!
Old Mar 12, 2003 | 12:28 AM
juani's Avatar
Rockin' VK56!!
I just punched it with my palm few times and pushed it really hard.
i ended up having new tatoo on my palm
you gotta aim it well before you punch it
Old Mar 12, 2003 | 05:13 AM
ZeRo MaX's Avatar
Use a blow dryer around the edges of your taillights. The goo is stick but not like super-glue... you should be fine if you take your time...
Old Mar 12, 2003 | 05:18 AM
BlueBOB's Avatar
Wow, I would have NEVER pushed.... that would hurt like a ****.
I helped a buddy do his this weekend and all we did was use a heat gun and pull from the outside. Unless I was pulling like a crazy psycho, I might have cracked something. Pulling them off the car is a cake walk as long as you've got a good heat gun (especially in the cold) to pull it out.
Old Mar 12, 2003 | 05:42 AM
pjalst
The Push/Pull method worked for me, you can push while another person pulls on the other side. It came out easy when I did it that way.
Old Mar 12, 2003 | 05:49 AM
StygianMax's Avatar
I did it sorta "bear hug" style. So one hand pushes against the light from the inside while the other hand is braced against the outside frame of the car. Both my lights popped out really easily that way.
Old Mar 12, 2003 | 07:39 AM
Indecisive311's Avatar
Don't get that goo on your clothes either. It stains like a ****.
Peace - Chad
Old Mar 12, 2003 | 08:25 AM
StygianMax's Avatar
No shiet! I killed my wifey's oven mitts with that goo.
Old Mar 12, 2003 | 09:22 AM
MrEous's Avatar
^ Jeff™
Heat gun definitely helped out wonders...Thanks again Chris!!!
Krazzespiinz
Sep 13, 2015 07:10 AM
JoshG
Sep 5, 2015 10:10 PM
220k+ A32
Aug 17, 2015 03:57 PM
dauntlessmax
Aug 5, 2015 10:29 AM
maximaxgtr
Mar 25, 2001 04:01 PM
