Car starts, then dies...
Old Mar 8, 2003 | 11:58 AM
maxdick's Avatar
When it's really cold out and I haven't started the car for hours (mornings), my max sometimes starts up then dies out after a second. This doesn't happen if I rev the engine when I start it up. Anyone know what the problem could be? I'm a little concerned.
Old Mar 8, 2003 | 12:02 PM
NYCe MaXiMa's Avatar
The same exact thing happens to me.
All the time when it's really cold..
It could be a number of things but a lot of people tell me it's normal i don't pay much attention to it anymore.
Old Mar 8, 2003 | 12:49 PM
KINGMAX's Avatar
You most likely have a bad Idle Air Coctrol Valve. Once the car heats up it runs ok right? But you have to keep on the gas in order to do this.
Old Mar 8, 2003 | 02:06 PM
andreyyy's Avatar
it can be dirty TB. and also oil if you put 10W30 in a winter time ,but it's not a big problem
Old Mar 8, 2003 | 02:10 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
your A.A.C valve is probebly dead. you need to replace that.
Old Mar 10, 2003 | 08:28 AM
blkmax97se's Avatar
I've been having exactly the same problem! Sounds like a common Maxima prob.
What is an A.A.C. valve?
Thanks!
Old Mar 10, 2003 | 09:36 AM
Canuck's Avatar
Thanks!
Old Mar 10, 2003 | 03:11 PM
Odie96's Avatar
I have a similar problem - after I decoded the "engine light" it said I needed an Engine coolant temp sensor. Has anyone changed one of these before? I just bought one and I want to put it in but I don't want to mess anything up.
Old Mar 10, 2003 | 03:49 PM
KINGMAX's Avatar
Thanks!
I think he means IAC valve, just what I said before. The symptoms you mention are common w/ a faulty IAC valve.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Stagnet04
Aug 16, 2015 11:15 PM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
