dashboard help...
Old Mar 8, 2003 | 07:37 PM
MIDNightMAX84's Avatar
dashboard help...
im taking out my stock headunit and putting in an aftermarket one. how do u take the dash apart to get to the headunit???
Old Mar 8, 2003 | 07:41 PM
sigepuca's Avatar
Here this should help.
http://carstereohelp.com/stereoremovalNisMax2.htm
Old Mar 9, 2003 | 05:34 PM
thanks for the help...
Old Mar 9, 2003 | 06:44 PM
XXXL Cracker's Avatar
Just did this two days ago....
Pop out Vents and clock console.....pry lightly witha trim tool or a screwdriver with tape on the tip. It will pop forward. Remove connectors and place on the dash.
Remove trim around the shifter. If you have an auto, put your car in N or D (make sure E brake is on).
Unclip connectore to cig lighter and place on the side.
There are two screws at the top of the center radio panel and two screws at the bottom. Remove them and the center consol will slide straight out.
You will need to remove the short screws holding in the stock HU to slide it out. On a double din Bose there are two connectors on the back.
Installation is the reverse of removal. If you have any questions, IM or email. Just finished a conversion to Alpine HU/CD/MPs player with XM radio. Kept the stock speakers and wired in a Peripheral control and harness. Sounds great, also am running an Infinity Basslink sub off of the HU.
D
gavin68
Sep 18, 2021 12:36 PM
vingodine
45
May 21, 2016 12:46 PM
yat70458
Aug 3, 2015 01:16 PM
RomieG
Jun 26, 2001 06:28 PM
MyMaxima97
Jun 22, 2001 10:34 PM
