PR CAI (Questions)
Old Mar 10, 2003 | 03:11 AM
looney662's Avatar
PR CAI (Questions)
I will be getting a PR CAI soon! I want to know what kind of shop should I go to, to get the hole cut out? How much would it cost? Thanks alot!
Old Mar 10, 2003 | 04:39 AM
Nismo's Avatar
do it at home. go get yourself a 3.50" hole saw bit for the electric drill. only takes 30 sec to cut the hole.
Old Mar 10, 2003 | 03:34 PM
looney662's Avatar
Will a dremel and a 3" disc work? Cause i don't have a drill!
Old Mar 10, 2003 | 04:35 PM
imstuckherenow's Avatar
ya need a drill, that metal is thin, but a ***** to cuz thru. if ya have one that plugs into the wall, that would help too. the battery powered one i tried wasnt strong enough
Old Mar 10, 2003 | 06:13 PM
blackmxma's Avatar
naw, I used a dremel and it worked allright....probably a little sloppier than a drill would be, but it all works out in the end, and you can't see the hole anyways once everythings installed.
Old Mar 10, 2003 | 07:02 PM
TitleistPrto's Avatar
Yeah its really easy to cut it, just buy the hle cutter from homedepot and then it takes two seconds to cut the hole.
Old Mar 10, 2003 | 08:43 PM
XXXL Cracker's Avatar
A dremel tool would do it.
-OR -
Go to Home Depot and rent a power drill and buy the bit. Rental cost on the tool is nil. Get a saw that plugs into the wall.
Much quicker and cleaner this way.
D
Old Mar 10, 2003 | 09:11 PM
Mad Dhan's Avatar
i started with the dremal.............taking too long......curse words............bought the hole saw bit. it was done in like 15 seconds. The bit was $12 for me a t Lowe's
Old Mar 10, 2003 | 10:11 PM
BOZOnPJs's Avatar
i'd paint around the bare metal to prevent rust.
Old Mar 10, 2003 | 10:42 PM
looney662's Avatar
Thanks alot for all the tips! I will try to get a drill some how!
Old Mar 10, 2003 | 11:13 PM
Nismo's Avatar
bug the neighbors!
Old Mar 11, 2003 | 03:41 AM
looney662's Avatar
Originally posted by Nismo
bug the neighbors!
I already did! So much trouble for a CAI! This thing better sound alot better and give me a gain that i can feel!
Unclejunebug
Apr 2, 2016 05:42 AM
Sep 27, 2015 08:37 AM
Socalstillen
Sep 26, 2015 12:01 PM
