Replacing Control arm bushings
Old Mar 10, 2003 | 12:22 PM
tweaked's Avatar
Hello all,
Does anyone have instructions on how to remove and replace the control arm bushings? I remember reading posts a while back about how hard they were to remove. Any tool I can create to ease the removal? Sorry, I normally perform searches for these king of questions.
Thank you very much,
Stephane
Old Mar 10, 2003 | 12:23 PM
blizz20oma's Avatar
I'm so hood
Someone earlier suggested to remove the control arm and take it to a machine shop & have them replace the bushings. I forget what you'd need to get the bushings off, a press of some sorts maybe?
Old Mar 10, 2003 | 02:24 PM
guido_sst's Avatar
The old bushings have to be drilled or burned out and the new bushings pressed into place.
Old Mar 11, 2003 | 12:23 AM
Velcro's Avatar
i've done this a couple of time with non foreign vehicles. if its the same you can pop the old ones out with an air chisel if you do it in the right places, and pop the new ones in with a large socket and a BFH
Old Mar 11, 2003 | 04:25 AM
tweaked's Avatar
Thanks everyone for your help, it seems that special tools are not required so I will try to remove them using force and brain
Thanks again,
SC
Old Mar 11, 2003 | 05:01 AM
glimmer1's Avatar
Thanks again,
SC
Do not try this without an air hammer.
I spent an 2 1/2 hours with a hand held hammer trying this.. I cant even tell you how much that sucked
Old Mar 11, 2003 | 05:07 AM
tweaked's Avatar
Thanks for the tip glimmer1, I get one before starting this project.
SC
Matt93SE
May 24, 2019 02:58 PM
maxocar
Aug 21, 2015 12:57 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
00 Max
Aug 4, 2015 07:09 PM
