How can you tell if a car has ABS?
Old Mar 10, 2003 | 03:25 PM
svarog's Avatar
Assuming the road is dry, and you don't want to take a year's life off the tires by stomping the brakes at 60 mph?
Old Mar 10, 2003 | 03:32 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Re: How can you tell if a car has ABS?
what trim of Maxima do you have?
Old Mar 10, 2003 | 03:34 PM
svarog's Avatar
Re: Re: How can you tell if a car has ABS?
95 GXE
Old Mar 10, 2003 | 03:36 PM
maxspeed96's Avatar
the abs sits right under the master cylinder. its a silver and gold metal box with brake lines attaching it to the master cylinder. theres also a green tag that says Nippon ABS LTD on the box. hope this helps.
Old Mar 10, 2003 | 03:39 PM
CystumMax's Avatar
Re: Re: Re: How can you tell if a car has ABS?
95 GXE
it would optional on your max to have an ABS. if you where the original owner of the car. they would tell u if you want abs. the GLE trims come with ABS. and yes as the other person said there is box inside of the engine on the right side behind the intake box its acutall right under the intake box. if you see that that means your car has it. there like 4 lines of break going into it.
Old Mar 10, 2003 | 03:50 PM
gregorwise's Avatar
abs
You can check by just looking at the fuse box and see if there is a fuse where it says abs "fuse box under the hood"
Old Mar 10, 2003 | 03:53 PM
meccanoble's Avatar
Sports Button FTW
GLE's come with it stock, most fully loaded SE's if not all come with it, a few GXE's come with it. THe easiest way to test is to just step in the car, and turn the key almost all the way where it will show all the icons lighted up on the dash. If ABS lights up, u have it
Old Mar 10, 2003 | 04:12 PM
slizan99's Avatar
Re: abs
i have the abs fuse box...... and it's empty
no abs
Old Mar 10, 2003 | 04:33 PM
WaarrEagle's Avatar
Early GLE's didn't come with it stock. I have a GLE w/o ABS. It was not standard until 1998.
Old Mar 10, 2003 | 04:48 PM
96shogunmax's Avatar
You guys were starting to scare me. I ran outside to check my car for abs b/c I bought some 5spd , locking diff, no abs ... axles for my conversion and didnt want to know that I waisted all that. I dont have it. Im in good shape.
Old Mar 10, 2003 | 04:56 PM
Dev's Avatar
Dev
seriously...if there is snow or rain...go to an empty parking lot or something (with no other cars around). go on a 5-10mph roll and jam the brakes. give yourself enough stopping distance.
your car shouldn't go out of control or anything...but just incase.
Old Mar 10, 2003 | 06:18 PM
bobjohnson's Avatar
Blazin......
MY SE has NO ABS>
i thought it did too. if you've been in a car with abs when it locks its amazing .
Youll feal each tires act on its own. the cars brakes will shake apply one after the other simoutanelously but not the pedal of it at all <thats abs.
Old Mar 11, 2003 | 10:08 AM
(_8*(l)Homer's Avatar
1. Go to a snow covered wal*mart parking lot.
2. Make sure there are very few cars there, if any at all.
3. Start from the adjacent end of the parking lot from the walmart bulding.
4. Drive towards the building at 30 mph
5. 60ft before hitting the building, depress the break as far as it will normally go.
6. If you hit the bulding, you have ABS, if you stop before the buliding, you don't have ABS.
ABS sucks in the snow.
My 2¢
(_8*(l)
Old Mar 11, 2003 | 10:13 AM
Socrates's Avatar
My 2¢
(_8*(l)
Yeah I think you're right.. I'd like to see some scientific trials.. I'm sure they're out there
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
