5spd problem
Old Mar 10, 2003 | 08:15 PM
SuperFishstick's Avatar
5spd problem
ok not to long ago my max started to make a weird noise when the clutch was depressed.. and when i would press the clutch in the noise would go away. It got worse now. Anywayz its making the noise now even when i'm in gear.. mostly 1st and 2nd. What could it be? should i change my transmission oil? i only have 40k
Old Mar 10, 2003 | 08:18 PM
maximum810's Avatar
Is your car still under the powertrain warranty? At 40k, is should be, but since it's a 98, I'm not entirely too sure. You should check incase is it is a tranny prob.
Old Mar 10, 2003 | 08:21 PM
heems27's Avatar
The powertrain warranty is for 5 yrs/60K miles, whichever comes first.
Check your clutch fluid and make sure you have enough. However, make sure you have someone check your tranny before it gets any worse.
Old Mar 10, 2003 | 08:27 PM
96shogunmax's Avatar
Throw out bearing???
Old Mar 10, 2003 | 08:30 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Re: 5spd problem
those hard shifting. and racing
Old Mar 10, 2003 | 08:56 PM
Dev's Avatar
Dev
Old Mar 10, 2003 | 09:39 PM
if its a bearing.. is that expensive?
27 bucks.
Old Mar 10, 2003 | 09:41 PM
Ramius83
If it is the throw-out bearing, it will require removal of the transmission. Because of that, it can be expensive. Do you have any friends with power or air tools? If so, you may want to consider doing it. Labor for the throw-out bearing will be around $300-$500 if you go to a shop....
Old Mar 10, 2003 | 09:47 PM
All this trouble for a $27 part. What a wonderful world.
I hope you people have hookups...
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
homewrecker
Sep 24, 2015 07:01 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
